I tried today to update my docker owncloud from 10.4.1 to 10.6.0
At first I couldn’t because I had enables apps that were not upgradable.
When I disabled them, the upgrade system stopped later in the process, while trying to change cron.d files times because of permission problems.
I tried to change the owner of these files to www-data and permissions to 777 but nothing changed
- Activate maintenance mode using
docker-compose exec owncloud occ maintenance:mode --on - Change version in .env to 10.6.0
- docker-compose pull
- docker-compose up -d
The upgrade system should automatically upgrade to 10.6.0
Upgrade stops while Touching cron configs with the following error :
Set mode for background jobs to 'cron'
owncloud_1 | Touching cron configs...
owncloud_1 | touch: setting times of '/etc/cron.d/e2scrub_all': Operation not permitted
owncloud_1 | touch: setting times of '/etc/cron.d/owncloud': Operation not permitted
owncloud_1 | touch: setting times of '/etc/cron.d/php': Operation not permitted
Operating system: Raspbian GNU/Linux 10 (buster)
Web server: ?
Database: webhippie/mariadb:latest
PHP version: 7.4.3
ownCloud version: 10.6.0
Updated from an older ownCloud or fresh install: Updated from 10.4.1
Where did you install ownCloud from: Docker hub
Signing status (ownCloud 9.0 and above): ?
Unavailable as the container won’t start
"system": {
"apps_paths": [
"url": "\/apps",
"writable": false
"path": "\/var\/www\/owncloud\/custom",
"url": "\/custom",
"writable": true
"trusted_domains": [
"localhost"
"datadirectory": "\/mnt\/data\/files",
"dbtype": "mysql",
"dbhost": "db",
"dbname": "owncloud",
"dbtableprefix": "oc_",
"log_type": "owncloud",
"supportedDatabases": [
"sqlite",
"mysql",
"pgsql"
"upgrade.disable-web": true,
"default_language": "en",
"overwrite.cli.url": "***REMOVED SENSITIVE VALUE***",
"htaccess.RewriteBase": "\/",
"logfile": "\/mnt\/data\/files\/owncloud.log",
"loglevel": 2,
"mysql.utf8mb4": true,
"filelocking.enabled": true,
"memcache.distributed": "\\OC\\Memcache\\Redis",
"redis": {
"host": "redis",
"port": "6379"
"version": "10.6.0.5",
"logtimezone": "Europe\/Paris",
"installed": true,
"instanceid": "oc0qzhwo92ba",
"mail_smtpmode": "smtp",
"mail_smtpauthtype": "LOGIN",
"mail_smtpauth": 1,
"mail_smtpport": "***REMOVED SENSITIVE VALUE***",
"mail_smtpsecure": "tls",
"maintenance": true
ownCloud is in maintenance mode - no app have been loaded
Enabled:
- activity: 2.6.0
- comments: 0.3.0
- configreport: 0.2.0
- dav: 0.6.0
- federatedfilesharing: 0.5.0
- federation: 0.1.0
- files: 1.5.2
- files_external: 0.7.1
- files_mediaviewer: 1.0.3
- files_pdfviewer: 0.11.2
- files_sharing: 0.14.0
- files_texteditor: 2.3.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- firstrunwizard: 1.2.0
- market: 0.6.0
- notifications: 0.5.2
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.4.0
- updatenotification: 0.2.1
Disabled:
- admin_audit
- announcementcenter
- customgroups
- encryption
- enterprise_key
- external
- files_antivirus
- files_classifier
- files_external_dropbox
- files_external_ftp
- files_ldap_home
- files_lifecycle
- firewall
- graphapi
- guests
- oauth2
- openidconnect
- password_policy
- ransomware_protection
- sharepoint
- systemtags_management
- theme-enterprise
- user_external
- user_ldap
- user_shibboleth
- windows_network_drive
- wopi
- workflow
Are you using encryption: no
Browser: Opera 74.0.3911.107
Operating system: Windows 10 Professional
owncloud_1 | Creating volume folders...
owncloud_1 | Creating hook folders...
owncloud_1 | Waiting for MySQL...
owncloud_1 | services are ready!
owncloud_1 | Waiting for Redis...
owncloud_1 | Writing config file...
owncloud_1 | Fixing base perms...
owncloud_1 | Fixing data perms...
owncloud_1 | Fixing hook perms...
owncloud_1 | ownCloud is in maintenance mode - no app have been loaded
owncloud_1 |
owncloud_1 | Upgrading server database...
owncloud_1 |
owncloud_1 | <warning>ownCloud is in maintenance mode</warning>
owncloud_1 | Maybe an upgrade is already in process. Please check the logfile (data/owncloud.log). If you want to re-run the upgrade procedure, remove the "maintenance mode" from config.php and call this script again.
owncloud_1 |
owncloud_1 |
owncloud_1 | Writing objectstore config...
owncloud_1 | Writing php config...
owncloud_1 |
owncloud_1 | Updating htaccess config...
owncloud_1 |
owncloud_1 | .htaccess has been updated
owncloud_1 | Writing apache config...
owncloud_1 | Enabling cron background...
owncloud_1 |
owncloud_1 | Set mode for background jobs to 'cron'
owncloud_1 |
owncloud_1 |
owncloud_1 |
owncloud_1 |
owncloud_1 |
owncloud_1 |
owncloud_1 |
This is repeating over and over
{"reqId":"eMtns8bbFL7UKNqO03Ac","level":0,"time":"1970-01-01T01:00:00+01:00","remoteAddr":"","user":"--","app":"core","method":"--","url":"--","message":"starting upgrade from 10.6.0.5 to 10.6.0.5"}
{"reqId":"eMtns8bbFL7UKNqO03Ac","level":3,"time":"1970-01-01T01:00:00+01:00","remoteAddr":"","user":"--","app":"core","method":"--","url":"--","message":"Exception: {\"Exception\":\"OC\\\\RepairException\",\"Message\":\"Upgrade is not possible\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Repair.php(90): OC\\\\Repair\\\\Apps->run()\\n#1 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Updater.php(219): OC\\\\Repair->run()\\n#2 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Updater.php(111): OC\\\\Updater->checkAppsCompatibility()\\n#3 \\\/var\\\/www\\\/owncloud\\\/core\\\/Command\\\/Upgrade.php(266): OC\\\\Updater->upgrade()\\n#4 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/symfony\\\/console\\\/Command\\\/Command.php(255): OC\\\\Core\\\\Command\\\\Upgrade->execute()\\n#5 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/symfony\\\/console\\\/Application.php(1009): Symfony\\\\Component\\\\Console\\\\Command\\\\Command->run()\\n#6 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/symfony\\\/console\\\/Application.php(273): Symfony\\\\Component\\\\Console\\\\Application->doRunCommand()\\n#7 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/symfony\\\/console\\\/Application.php(149): Symfony\\\\Component\\\\Console\\\\Application->doRun()\\n#8 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Console\\\/Application.php(165): Symfony\\\\Component\\\\Console\\\\Application->run()\\n#9 \\\/var\\\/www\\\/owncloud\\\/console.php(116): OC\\\\Console\\\\Application->run()\\n#10 \\\/var\\\/www\\\/owncloud\\\/occ(11): require_once('\\\/var\\\/www\\\/ownclo...')\\n#11 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Repair\\\/Apps.php\",\"Line\":219}"}
