Impossible to upgrade to 9.0.4
Il try to upgrade 9.0.1 to 9.0.4 but it doen’t work.
I copy log section :
Error PHP Undefined index: REQUEST_URI at /home/antipodebq/www/owncloud/lib/base.php#179
Zend OPcache API is restricted by “restrict_api” configuration directive
at /home/antipodebq/www/owncloud/lib/private/util.php#1365
Thanks for your help.
Please provide more information:
  • How did you update?
  • Where did you get this “undefined index”
  • Have you used your favorite search engine to search for the Zend OPcache API is restricted by "restrict_api" configuration directive error?
I tried to update with the “updater” tool in the administration section of my owncloud : “A new version is available: ownCloud 9.0.4”
The two error are listed in the “log” section.
When I clicked on the buton nothing happened…
Only 2 new lines in the log and a “‘updater.secret’ =>…” line in config.php.
Owncloud is installed on an OVH shared server.
Thanks.
as an alternative just to the manual update like described here:
This is recommended anyway as the updater app has shown tons of issues in the past and is just broken in my PoV.
How can I launch the upgrade from the command line using occ on shared hosting server ?
You don’t need to run the upgrade via command line. Just delete all files and folders except /data/ and /config/ and extract the 9.0.4 archive to the install dir.
Yes. Thanks…
It is important to remember to change access rights to files without which as " forbiden access " page appears.
So I updated to the 9.1… No problem.
I will use this method…
