- Copy a file (.exe) to Owncloud folder
- Drag and drop file (.exe) to Owncloud web interface
Copy works…
Impossible to copy “.exe”
“Connection closed”
Ubuntu 16.04.5 LTS
Apache/2.4.18 (Ubuntu)
mysql Ver 14.14 Distrib 5.7.23, for Linux (x86_64)
PHP 7.0.30-0ubuntu0.16.04.1 (cli) ( NTS )
ownCloud X
"system": {
"trusted_domains": [
"localhost",
"datadirectory": "\/var\/ocdata",
"overwrite.cli.url": "https:",
"dbtype": "mysql",
"version": "10.0.4.4",
"dbname": "owncloud_db",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"logtimezone": "UTC",
"installed": true,
"instanceid": "***REMOVED SENSITIVE VALUE***",
"appstore.experimental.enabled": "true",
"mail_smtpmode": "smtp",
"mail_smtpport": "25",
"preview_libreoffice_path": "\/usr\/bin\/libreoffice",
"memcache.local": "\\OC\\Memcache\\Redis",
"filelocking.enabled": true,
"memcache.distributed": "\\OC\\Memcache\\Redis",
"redis": {
"host": "\/var\/run\/redis\/redis.sock",
"port": 0,
"timeout": 0,
"dbindex": 0,
"password": "***REMOVED SENSITIVE VALUE***"
"htaccess.RewriteBase": "\/",
"mysql.utf8mb4": true,
"maintenance": false,
"loglevel": 3,
"theme": "",
"singleuser": false
Enabled:
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.3.2
- encryption: 1.3.1
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_sharing: 0.10.1
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- firstrunwizard: 1.1
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- updatenotification: 0.2.1
Disabled:
- contacts
- external
- files_videoplayer
- market
- notifications
- templateeditor
- theme-example
- user_external
no
Are you using encryption:
yes
no
[ warning sync.networkjob ]: QNetworkReply::NetworkError(RemoteHostClosedError) "Connection closed" QVariant(Invalid)
