I used to run a nextcloud instance but i shut it down due to performance issues and a mysterious issue in which users using kodi on an xbox which was connecting via Webdav via https.
Due to my current method of allowing uses to connect and sync there files via sftp is a tad more work, so i was looking into the whole Webdav thing again and it boils down to this.
Owncloud seems to rank higher than Nextcloud im not looking for anything to fancy like chat options or word processing just a nice easy to use cloud which allows user’s to use Webdav via https without much issues.
My system specs are
AMD Ryzen 3 2300X Quad-Core
8GB DDR 4 ram
Running Kbuntu 21.04
