Incorrect link in "Tips & Tricks"
  1. login to ownCloud as admin
  2. go to ‘admin’ page, click “Tips & Tricks” link on the left hand side
  3. click any of the six bullet points
it points to administration manual for v8
Web server: doesn’t matter
Database: doesn’t matter
PHP version: doesn’t matter
ownCloud version (see ownCloud admin page): 9.1.1
Integrity status for oC9+
paste the results here.
Technical information
them.
Results
- core
	- INVALID_HASH
		- core/doc/admin/_sources/configuration_files/collaborative_documents_configuration.txt
		- core/fonts/LICENSE.txt
- files_external
	- INVALID_HASH
		- 3rdparty/Dropbox/API.php
Raw output
Array
    [core] => Array
            [INVALID_HASH] => Array
                    [core/doc/admin/_sources/configuration_files/collaborative_documents_configuration.txt] => Array
                            [expected] => 251befed4a319c8e4b390b363a9bc8079b54991891204a4ff1cb551797931ba9f276903e1e5e8bde932afcb5e67d23f7939cea22e68c6bd7695e2b8ce654c5b3
                            [current] => 637ac6c02e3ef06cc19a9b465c5c0e6ae6777f9e5d5d52cae28482f350e3b348a5c3ba67ae693e95971373c326af98c27c7f04492aa836b6ab1348f7341ccb29
                    [core/fonts/LICENSE.txt] => Array
                            [expected] => 4cc5a12bfe984c0a50bf7943e2d70a948d520ef423677c77629707aace3a95aa378d205de929105d644680679e70ef2449479b360ad44896b75bafed66613272
                            [current] => 98f6b79b778f7b0a15415bd750c3a8a097d650511cb4ec8115188e115c47053fe700f578895c097051c9bc3dfb6197c2b13a15de203273e1a3218884f86e90e8
    [files_external] => Array
                    [3rdparty/Dropbox/API.php] => Array
                            [expected] => a6866ef3ceeb26d9d4b2ccc343aeaf626c82f03e279962bc7d761a68e87e5a7916ff0bcf7a350e20889557336ed9c5dd1651cfe513fa04bb8a03cd6d8f9cc484
                            [current] => 917eed2c4f6359a4d0b8658a36404c83344b0bf72ccda614dd59f97d099b3d9ef4e86691401c64d3754c3f7e0fa163eab946a25dbc7bc65e1694ffd47a054317
mhhh thats a strange one. The links at the demo are correct:
https://demo.owncloud.org/index.php/settings/admin
Any chances that you’re using the example theme?
Voila!
I use my own theme, but copied it from sample config, have been using it since version 8.0.
HOWEVER, looking at the ‘/themes/example/default.php’ file (line 142), it still says ‘/server/8.0/go.php’
