- Installed MySQL 8
- Created User and database
- Installed httpd 2.4
- created virtual host with domain and ssl (letsencrypt)
- Installed nginx as revers proxy for domain and redirecting to https
- Downloaded and installed owncloud from commandline
- Fixed issue with mysql 8 and mysql_native_password
- Opend URL http://domain/owncloud -> Redirects via ngnix to 127.0.0.1:8443
Browser opening owncloud login-page
Error message not trusted domain -> Added domain and 127.0.0.1 to trusted domains in
maintenance mode caused in error message
Not Found
The requested URL /indx.php was not found on this server.
Operating system: centos 7.7
Web server: nginx revers proxy to httpd 2.4
Database: mysql 8
PHP version: php 7.2 with fast cgi
ownCloud version: (see ownCloud admin page) 10.4.1
Where did you install ownCloud from: downloaded from owncloud server owncloud-latest.tar.bz2
Are you using encryption: no, just https via letsencrypt
Are you using an external user-backend, if yes which one: no.
<?php
$CONFIG = array (
'passwordsalt' => 'sensitive data',
'secret' => 'sensitive data',
'trusted_domains' =>
array (
0 => 'localhost',
1 => '127.0.0.1',
2 => 'domain.com',
3 => 'domain',
4 => 'www.domain.com',
'datadirectory' => '/opt/owncloud/data',
'overwrite.cli.url' => 'http://localhost',
'dbtype' => 'mysql',
'version' => '10.4.1.3',
'dbname' => 'sensitive data',
'dbhost' => 'sensitive data',
'dbtableprefix' => 'oc_',
'mysql.utf8mb4' => true,
'dbuser' => 'sensitive data',
'dbpassword' => 'sensitive data',
'logtimezone' => 'UTC',
'apps_paths' =>
array (
0 =>
array (
'path' => '/var/www/domain/html/owncloud/apps',
'url' => '/apps',
'writable' => false,
1 =>
array (
'path' => '/var/www/domain/html/owncloud/apps-external',
'url' => '/apps-external',
'writable' => true,
'installed' => true,
'instanceid' => 'oc5x3byp76g3',
'maintenance' => false,
Browser: Firefox
Operating system: Windows 10
{"reqId":"XqFU2BfBA9nk0hTuEXTHwwAAAAA","level":2,"time":"2020-04-23T10:42:00+02:00","remoteAddr":"127.0.0.1","user":"--","app":"core","method":"GET","url":"\/owncloud\/index.php","message":"Trusted domain error. \"127.0.0.1\" tried to access using \"domain\" as host."}
{"reqId":"XqFU2BfBA9nk0hTuEXTHxAAAAAA","level":2,"time":"2020-04-23T10:42:00+02:00","remoteAddr":"127.0.0.1","user":"--","app":"core","method":"GET","url":"\/owncloud\/cron.php","message":"Trusted domain error. \"127.0.0.1\" tried to access using \"domain\" as host."}
