- Fresh server build, download owncloud from official source. Unzip and configure web server.
- Go to OwnCloud installation wizard
- Enter in existing db name, db admin and db admin password.
The new installation connects to the existing database.
Installation wizard fails, see logs below.
For the purpose of this SELinux has been disabled but will be enabled for production.
OwnCloud attempts to create oc_root account and fails because it already exists, and it creates another account with oc_root1 oc_root2 etc. See screenshot below:
Operating system: CentOS 7
Web server: Apache
PHP version: 5.4.16
Updated from an older ownCloud or fresh install: Fresh Install
External Storage, external authentication, reverse proxy and server-side encryption.
{"reqId":"WOTRGhPtOkSI7xOFEDnggQAAAAU","remoteAddr":"10.1.10.xxx","app":"mysql.setup","message":"Database creation failed: An exception occurred while executing 'GRANT ALL PRIVILEGES ON `owncloud` . * TO 'oc_root'':\n\nSQLSTATE[42000]: Syntax error or access violation: 1044 Access denied for user 'oc_root'@'%' to database 'owncloud'","level":3,"time":"2017-04-05T11:12:26+00:00","method":"POST","url":"\/index.php","user":"--"}
Integrity status for oC9+
paste the results here.
Not setup yet
Seen this post here but it references a postgres db: Post
Also seen the following ‘feature’ request (although i’m not sure this is a feature request more a bug?). One of the posters mentions that it should work for MySQL databases. Feature Request
