integrate ocis with collabora in kubernetes
Dear OCIS Community,
I’m deploying ocis and collabora using kubernetes, on on-premise, i want to integrate collabora with ocis as viewer,
Can you help on the integration, the necessary Environment variables to make collabora as viewer to ocis
Hello Ala,
What documentation are you following?
There are several links that could be helpful:
https://owncloud.dev/services/collaboration/
https://github.com/owncloud/ocis-charts
https://github.com/owncloud/ocis/blob/master/deployments/examples/ocis_full/collabora.yml
hello @2403905
Thanks for your replay,
i deploy collaboration service with required env with its own doman, and i deployed collabora with its own domain,
what i need to do in the side of ocis to get it works, i didn’t understand well enough how is the workflow between ocis, collaboration and collabora
