I tried disabling, uninstalling, reenabling, nothing seems to fix the problem. Any hints welcome. I don't use this app and there is no obvious problems with ownCloud otherwise. Would be nice to clean this up though, and get rid of the persistent error message.
- log into the web interface
2.
3.
no error message
error message with integrity check
Operating system: Ubuntu 16.04.4
Web server: Apache 2.4.18
Database: PHP version: 5.6.28
ownCloud version: 10.0.7
Updated from an older ownCloud or fresh install: 10.0.4
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): None
ownCloud log:
{"reqId":"enJOxpQVX8DB7gty1X0F","remoteAddr":"73.167.246.98","app":"PHP","message":"mkdir(): Permission denied at \/var\/www\/owncloud\/lib\/private\/Setup.php#288","level":3,"time":"2016-08-01T06:26:27+00:00","method":"POST","url":"\/owncloud\/index.php","user":"--"}
Technical information
them.
Results
- templateeditor
- FILE_MISSING
- l10n/mk.js
- l10n/mk.json
- lib/AppInfo/Application.php
- lib/Controller/AdminSettingsController.php
- lib/Http/MailTemplateResponse.php
- EXTRA_FILE
- Makefile
- l10n/mk.php
- FILE_MISSING
Raw output
Array
[templateeditor] => Array
[FILE_MISSING] => Array
[l10n/mk.js] => Array
[expected] => 59c1253859c1af4541b303152a95e3ae7dee3bcc3f4b4e03ae399ac7a7f20fd83219c6d654cd2f49817ddfdec1e96abe402cacfba497e6a5f6106b16ce3fa1b5
[current] =>
[l10n/mk.json] => Array
[expected] => f558578603f20f0b4585b37cb2d163806b5fe0bfdbe3ee333412c012f6ddcc0163932ad55f56e8917281e7342883f487bad57805991a72eae86446faf7a0090a
[current] =>
[lib/AppInfo/Application.php] => Array
[expected] => 2adaf88f7b57b1bcba689e51b54e11f419b2d4f93ccd36fa560d42e91046a8709a25c040e36385d398c12ce4a222b11b00849ff06916f48d12db3c3a67bc5cab
[current] =>
[lib/Controller/AdminSettingsController.php] => Array
[expected] => b200a3dd882ffd95ad0076f0c6ef15962ce9ee09ed960d3325bbfbb8c77e9aae1845ed6eb3fd8bcfac99c4c192b546e527c43f7e14d0b03e313f4d2414816a73
[current] =>
[lib/Http/MailTemplateResponse.php] => Array
[expected] => 798ee5140f241c6ce0e4c9ed2d31c5d32f91c41be42977579624b07cd02b2a7ba5a4970f647509b43bff8efc4a831dc482c6affd887c5fe6853b03620fa4ac02
[current] =>
[EXTRA_FILE] => Array
[Makefile] => Array
[expected] =>
[current] => 8ac57be439422bb259461e99361e86392395c91efeb0525b1a36b5f081334e9c8993c46e664d8ac1b31473052701420d8a3513e7a5270148b68afd7938cfa069
[l10n/mk.php] => Array
[expected] =>
[current] => ce1715a6789d5e6f63dd804edcddbc7b6ca942d886e0a5fb29496cf5f822e4b2661167dcebeb94b6ab6f09ca91ec7f25c2020454ab516a1997f328a76f6358e3
