Upgrade from 10.4.1.3 to 10.6.0
Upgrade to 10.6.0 completed (successfully) however the integrity check failed
Operating system: Ubuntu 18.04 (all packes are up to date)
**Web server: Apache/2.4.29
**Database: 10.1.47-MariaDB
**PHP version: 7.2.24
**ownCloud version: 10.4.1
**Updated from an older ownCloud or fresh install: it was a fresh 10.4.1 install before I tried to upgrade to 10.6.0
I downloaded the tar file from the ownncloud website and followed the upgrade process. The following apps are installed on the server:
Enabled:
- comments: 0.3.0
- configreport: 0.2.0
- dav: 0.5.0
- federatedfilesharing: 0.5.0
- federation: 0.1.0
- files: 1.5.2
- files_external: 0.7.1
- files_mediaviewer: 1.0.2
- files_sharing: 0.12.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- firstrunwizard: 1.2.0
- impersonate: 0.5.0
- market: 0.5.0
- notifications: 0.5.0
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- updatenotification: 0.2.1
- user_ldap: 0.15.2
Disabled: - encryption
- external
- user_external
I already disabled the most apps for the upgrade (I looked the docu which are supported) but after the upgrade I get the message that the integrity check failed.
Technical information
them.
Results
- EXTRA_FILE
- l10n/de_AT.json
- l10n/de_CH.json
- l10n/de_CH.js
- l10n/de_AT.js
- EXTRA_FILE
- files_external
- EXTRA_FILE
- l10n/de_CH.json
- l10n/de_CH.js
- 3rdparty/phpseclib/phpseclib/phpseclib/Math/BigInteger.php
- 3rdparty/phpseclib/phpseclib/phpseclib/System/SSH/Agent/Identity.php
- 3rdparty/phpseclib/phpseclib/phpseclib/System/SSH/Agent.php
- 3rdparty/phpseclib/phpseclib/phpseclib/Net/SFTP.php
- EXTRA_FILE
- dav
- EXTRA_FILE
- appinfo/Migrations/Version20200114181454.php
- appinfo/Migrations/Version20200427142541.php
- l10n/de_CH.json
- l10n/de_CH.js
- EXTRA_FILE
- EXTRA_FILE
- l10n/de_CH.json
- l10n/de_CH.js
- EXTRA_FILE
- federation
- EXTRA_FILE
- l10n/de_CH.json
- l10n/de_CH.js
- EXTRA_FILE
- files_trashbin
- EXTRA_FILE
- l10n/de_CH.json
- l10n/de_CH.js
- EXTRA_FILE
- files_sharing
- EXTRA_FILE
- appinfo/Migrations/Version20200823121322.php
- appinfo/Migrations/Version20200504211654.php
- l10n/de_CH.json
- l10n/de_CH.js
- lib/External/ScanExternalSharesJob.php
- EXTRA_FILE
- notifications
- EXTRA_FILE
- l10n/el.json
- l10n/nl.json
- l10n/tr.json
- l10n/zh_CN.js
- l10n/nl.js
- l10n/zh_CN.json
- l10n/tr.js
- l10n/el.js
- EXTRA_FILE
- files
- EXTRA_FILE
- l10n/de_CH.json
- l10n/de_CH.js
- lib/Command/TroubleshootTransferOwnership.php
- EXTRA_FILE
- comments
- EXTRA_FILE
- l10n/de_CH.json
- l10n/de_CH.js
- EXTRA_FILE
- files_versions
- EXTRA_FILE
- l10n/de_CH.json
- l10n/de_CH.js
- EXTRA_FILE
- systemtags
- EXTRA_FILE
- l10n/de_CH.json
- l10n/de_CH.js
- EXTRA_FILE
Array
[federatedfilesharing] => Array
[EXTRA_FILE] => Array
[l10n/de_AT.json] => Array
Does anybody knows what I could do
