- log into the web interface
no error message
error message with integrity check
Operating system: synology
Web server: Apache 2.2
PHP version: 5.6.28
ownCloud version (see ownCloud admin page):9.1.4
Integrity status for oC9+
paste the results here.
Technical information
them.
Results
- core
- EXTRA_FILE
- 3rdparty/.gitignore
- 3rdparty/bantu/ini-get-wrapper/.gitignore
- 3rdparty/doctrine/cache/.gitignore
- 3rdparty/doctrine/collections/.gitignore
- 3rdparty/doctrine/common/.gitignore
- 3rdparty/doctrine/common/.gitmodules
- 3rdparty/doctrine/inflector/.gitignore
- 3rdparty/icewind/streams/.gitignore
- 3rdparty/lukasreschke/id3parser/.gitignore
- 3rdparty/pear/archive_tar/.gitignore
- 3rdparty/pear/console_getopt/.gitignore
- 3rdparty/pear/pear-core-minimal/.gitignore
- 3rdparty/pear/pear_exception/.gitignore
- 3rdparty/rackspace/php-opencloud/.gitignore
- 3rdparty/react/promise/.gitignore
- 3rdparty/sabre/dav/.gitignore
- 3rdparty/sabre/event/.gitignore
- 3rdparty/sabre/http/.gitignore
- 3rdparty/sabre/uri/.gitignore
- 3rdparty/sabre/vobject/.gitignore
- 3rdparty/sabre/xml/.gitignore
- core/doc/admin/configuration_database/db_conversion.html
- core/doc/admin/configuration_database/index.html
- core/doc/admin/configuration_database/linux_database_configuration.html
- core/doc/admin/configuration_files/big_file_upload_configuration.html
- core/doc/admin/configuration_files/collaborative_documents_configuration.html
- core/doc/admin/configuration_files/default_files_configuration.html
- core/doc/admin/configuration_files/encryption_configuration.html
- core/doc/admin/configuration_files/external_storage/amazons3.html
- core/doc/admin/configuration_files/external_storage/auth_mechanisms.html
- core/doc/admin/configuration_files/external_storage/dropbox.html
etc..... almost all files !
