- Modified some graphics in
owncloud/core/imgto change the site logo and favicon. - Also modified
owncloud/core/css/header.cssto change colors. - Server integrity check now reports invalid hash errors for the modified files.
These files are intentionally modified, so i’m looking for some way to commit them, so integrity check passes.
Integrity check passes with modified images and css.
Integrity check fails, with this:
Technical information
them.
Results
- core
- INVALID_HASH
- core/css/header.css
- core/img/favicon.ico
- core/img/background.jpg
- core/img/logo.svg
- core/img/favicon.svg
Raw output
Array
[core] => Array
[INVALID_HASH] => Array
[core/css/header.css] => Array
[expected] => 47eecc8ee5515878f9491bbb6c9f750047fb7841ad51b9f898f0f67814b22598207007dfb4e43ace861529187e0deed91cbceb5b73c73d99ef7c62c57f829e92
[current] => 229b46481419d7c09b645e244f5324fcbbe37788b22730c183067cd998728b742f0ffc36041a4641c3d0e14176363ab08d0185fd6de1d5cd4acf8d9d1249061c
[core/img/favicon.ico] => Array
[expected] => 5f31605962147f1bd828102cc5db006c5da78697a5f5b2300f847dca2643377b369bf3b08603f3789591fa9a69d91556ea286f39d081833f42689c44eb848c50
[current] => 2d723f40546ca9d59b2b454bbe87e7b38060b19303f7bb203c788b45c1a252afb2a50ca5bab59b2a9fcca949ea51d6b4ff9d2e30900a356e7aa7de4aaa7833bd
[core/img/background.jpg] => Array
[expected] => 34f73c41969d08c59ee3c550a9c6245ca722318a440e1465e2a5263453e7aa7b69d2b681d422e7c7ace3fcd658f3ba47c3cb5a88bc5e172cc7d2118bbd156b79
[current] => 95b454d19a8b5f6586301da10dde0fefc1e622daf3ec39a2201fb3895362c138145bfcc9a65cfbef6da9f45f370b0156307c0740db5a06ac747204d854e9791c
[core/img/logo.svg] => Array
[expected] => 0fed54bd7c739cf9fb09ed57d9f2c751579db063418382bb5c4937e4b57cfc399c6752695b41d44a11cc4fab1fa3a9cf20384479c3a9ec74d39b035c1811dcfc
[current] => 3a1bad1e3e32962650c2d70250c97470fcf31c5ae740085884359462a76825c2d5c7ef0e30d38730da2c16291d1ce6764d19174aeb59020960e9e0fa4c6fcea8
[core/img/favicon.svg] => Array
[expected] => a665e874427b7e11fc6676a311639ed63a2d69f1f37fdeb8702fa2d650d8875c60ff9f4ba802131fa779d74fa31950e0032877c82db127c9bd06ce27955e6f81
[current] => 1b4e05536209a06d913eab040ad6223a72d424a24d153a3d9aa9fc6694f7a11732933ccd3ab07a98510fb52f65b5374b1955e0c282c46dc6652bb232bc4e26ad
ubuntu 14
apache
PHP
PHP 7.0.21-1~ubuntu14.04.1+deb.sury.org+1
mysql
10.0.3
originally installed version 9.
