Intergration Of Owncloud
Hello everyone,
Can we intergrate owncloud to a WordPress website?
  • Can you explain what that looks like to you?
  • What elements are you hoping to integrate?
  • Can you describe the use case in more detail?
Hi, I want to integrate the login system of my website, with the login of owncloud.
Is that possible? I am unable to mention the link of my website, so can you help me out? Thank you.
If you are simply looking for a centrally managed identity solution that can manage users who need access to both your ownCloud instance and a WordPress instance, that can be done.
The specifics drift off topic for this forum. Using an identity provider that has LDAP access would offer native integration with ownCloud and the Authorizer plugin adds that capability to WordPress.
