Hi! I had OwnCloud working well, but needed to reinstall. This time I chose to use an unsigned certificate for SSL/HTTPS access, simply clicking the appropriate checkbbox in the admin page through my browser. Calendars sync well and web access through a browser is also working through https. However, i get the following error when starting the OwnCloud sync program on my client box:
]an internal error number 1060 happened server certificate was missing commonname attribute in subject name
restarting apache on the server gives this:
Could not reliably determine the server’s fully qualified domain name, using 127.0.1.1 for ServerName
httpd (pid2080) already rung\ning
From advice on this post, II tried viewing the SSL certificate by entering:
openssl x509 -noout -text -in ssl.crt
but was informed:
Error opening Certificate ssl.crt
3074087176:error:02001002:system library:fopen:No such file or directory:bss_file.c:398:fopen(‘ssl.crt’,‘r’)
3074087176:error:20074002:BIO routines:FILE:CTRLsystem lib:bss_file.c:400:
unable to load certificate
The above link suggested generating a new “snake oil certificate”
but I’m a bit nervous about doing that, having it fail, and me having to reinstall all over again. The only other advice I found was rather generic at this this post about eliminating SSL errors…and that seems even riskier.
I could revert to using simple http as before, perhaps that is not so bad since I’m blocking all unknown MAC addresses and live in a rather quiet suburban (almost rural!) neighborhood…but if I can, I’d like to use SSL.
So – any advice? My commandline knowledge is rudimentary at best, so please keep instructions clear and step-by-step. Or, if perhaps the advice given on one of the two websites linked to (above) seems fairly safe, do let me know that and I’ll give it a shot.
Thanks in advance!
