Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
Technical details
Remote Address:
Request ID: Ih1+hIdb+240xuh5+TvH
Many times tried.But failed
I would like to install ownCloud in my Docker cloud.
System: Debian 7.8
Linux+Nginx+MariaDB5.5+PHP7+Apache2.4
phpinfo is ok
My server Url is http://disk.lxam.cn
http://disk.lxam.cn/data/owncloud.log
{“reqId”:“Ih1+hIdb+240xuh5+TvH”,“remoteAddr”:“10.0.51.200”,“app”:“mysql.setup”,“message”:“Specific user creation failed: An exception occurred while executing ‘SELECT user FROM mysql.user WHERE user=?’ with params ["oc_lxam"]:\n\nSQLSTATE[42000]: Syntax error or access violation: 1142 SELECT command denied to user ‘owncloud’@‘localhost’ for table ‘user’”,“level”:3,“time”:“2016-08-01T07:37:56+00:00”,“method”:“POST”,“url”:“/index.php”,“user”:“–”}
{“reqId”:“Ih1+hIdb+240xuh5+TvH”,“remoteAddr”:“10.0.51.200”,“app”:“mysql.setup”,“message”:“Database creation failed: An exception occurred while executing ‘GRANT ALL PRIVILEGES ON owncloud . * TO ‘owncloud’’:\n\nSQLSTATE[42000]: Syntax error or access violation: 1410 You are not allowed to create a user with GRANT”,“level”:3,“time”:“2016-08-01T07:37:56+00:00”,“method”:“POST”,“url”:“/index.php”,“user”:“–”}
{“reqId”:“Ih1+hIdb+240xuh5+TvH”,“remoteAddr”:“10.0.51.200”,“app”:“index”,“message”:“Exception: {"Exception":"Doctrine\\DBAL\\Exception\\DriverException","Message":"An exception occurred while executing ‘CREATE TABLE oc_addressbooks (id BIGINT UNSIGNED AUTO_INCREMENT NOT NULL, principaluri VARCHAR(255) DEFAULT NULL, displayname VARCHAR(255) DEFAULT NULL, uri VARCHAR(255) DEFAULT NULL, description VARCHAR(255) DEFAULT NULL, synctoken INT UNSIGNED DEFAULT 1 NOT NULL, UNIQUE INDEX addressbook_index (principaluri, uri), PRIMARY KEY(id)) DEFAULT CHARACTER SET utf8 COLLATE utf8_bin ENGINE = InnoDB’:\n\nSQLSTATE[42000]: Syntax error or access violation: 1071 Specified key was too long; max key length is 1000 bytes","Code":0,"Trace":"#0 \/home\/wwwroot\/disk.lxam.cn\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/DBALException.php(116): Doctrine\\DBAL\\Driver\\AbstractMySQLDriver->convertException(‘An exception oc…’, Object(Doctrine\\DBAL\\Driver\\PDOException))\n#1 \/home\/wwwroot\/disk.lxam.cn\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Connection.php(945): Doctrine\\DBAL\\DBALException::driverExceptionDuringQuery(Object(Doctrine\\DBAL\\Driver\\PDOMySql\\Driver), Object(Doctrine\\DBAL\\Driver\\PDOException), ‘CREATE TABLE o...')\\n#2 \\\/home\\\/wwwroot\\\/disk.lxam.cn\\\/lib\\\/private\\\/DB\\\/MDB2SchemaManager.php(168): Doctrine\\\\DBAL\\\\Connection->query('CREATE TABLE o…’)\n#3 \/home\/wwwroot\/disk.lxam.cn\/lib\/private\/DB\/MDB2SchemaManager.php(69): OC\\DB\\MDB2SchemaManager->executeSchemaChange(Object(Doctrine\\DBAL\\Schema\\Schema))\n#4 \/home\/wwwroot\/disk.lxam.cn\/lib\/private\/legacy\/db.php(172): OC\\DB\\MDB2SchemaManager->createDbFromStructure(‘\/home\/wwwroot\/d…’)\n#5 \/home\/wwwroot\/disk.lxam.cn\/lib\/private\/Installer.php(563): OC_DB::createDbFromStructure(‘\/home\/wwwroot\/d…’)\n#6 \/home\/wwwroot\/disk.lxam.cn\/lib\/private\/Installer.php(539): OC\\Installer::installShippedApp(‘dav’)\n#7 \/home\/wwwroot\/disk.lxam.cn\/lib\/private\/Setup.php(379): OC\\Installer::installShippedApps()\n#8 \/home\/wwwroot\/disk.lxam.cn\/core\/Controller\/SetupController.php(64): OC\\Setup->install(Array)\n#9 \/home\/wwwroot\/disk.lxam.cn\/lib\/base.php(829): OC\\Core\\Controller\\SetupController->run(Array)\n#10 \/home\/wwwroot\/disk.lxam.cn\/index.php(39): OC::handleRequest()\n#11 {main}","File":"\/home\/wwwroot\/disk.lxam.cn\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/AbstractMySQLDriver.php","Line":115}”,“level”:3,“time”:“2016-08-01T07:37:56+00:00”,“method”:“POST”,“url”:“/index.php”,“user”:“–”}
{“reqId”:“Ih1+hIdb+240xuh5+TvH”,“remoteAddr”:“10.0.51.200”,“app”:“PHP”,“message”:“scandir() has been disabled for security reasons at /home/wwwroot/disk.lxam.cn/lib/private/L10N/Factory.php#183”,“level”:3,“time”:“2016-08-01T07:37:56+00:00”,“method”:“POST”,“url”:“/index.php”,“user”:“–”}
{“reqId”:“Ih1+hIdb+240xuh5+TvH”,“remoteAddr”:“10.0.51.200”,“app”:“PHP”,“message”:“Invalid argument supplied for foreach() at /home/wwwroot/disk.lxam.cn/lib/private/L10N/Factory.php#185”,“level”:3,“time”:“2016-08-01T07:37:56+00:00”,“method”:“POST”,“url”:“/index.php”,“user”:“–”}
{“reqId”:“Ih1+hIdb+240xuh5+TvH”,“remoteAddr”:“10.0.51.200”,“app”:“PHP”,“message”:“chmod(): No such file or directory at /home/wwwroot/disk.lxam.cn/lib/private/Log/Owncloud.php#114”,“level”:3,“time”:“2016-08-01T07:37:56+00:00”,“method”:“POST”,“url”:“/index.php”,“user”:“–”}
