Interpretation of logfiles generated by oC
It seems like there is no actual content in your post other then the empty skeleton. Not sure what happened there, but perhaps you can edit your post to add your content?
In case you have a question, please ask. If something doesn’t work, fill out the issue-template, at least the related parts.
