containing all needed info. When updating your installation make sure that you're also copying / uploading the .htaccess file as some file browsers or FTP clients are not showing such hidden files by default.
Please avoid to push threads with questions not directly related to the original post. As there is no feedback of the OP i'm assuming this was solved and closing this issue. If you have further questions please create a new thread.
Short hint: Just edit the .htaccess file at the correct place. This would be below the following:
