- Install ESXi appliance
- Upload license file received by mail
- Run all available updates
- Open owncloud - login windows says license is invalid
The license file I received by e-mail should work in free version.
It says the license key is invalid
ESXi appliance downloaded from httpx://owncloud.com/download-server/
Result of index.php/settings/integrity/failed
Too big to be pasted here
No
No
No
Opera
{"reqId":"9RxX7UZuRcBMvsM9wtK9","level":0,"time":"2024-02-14T06:03:55+00:00","remoteAddr":"","user":"--","app":"core","method":"--","url":"--","message":"starting upgrade from 10.13.2.3 to 10.13.4.1"}
{"reqId":"RgBw98wtDQr57WcbRy0i","level":3,"time":"2024-02-14T06:09:48+00:00","remoteAddr":"172.17.42.1","user":"--","app":"PHP","method":"GET","url":"\/owncloud\/login","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"zhhdXY5AHQG1NsHdVMiL","level":3,"time":"2024-02-14T06:15:26+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=0c4296af745ea40d3d08b95384bf30ad","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"Xsnv5ezDtIGZojZW731s","level":3,"time":"2024-02-14T06:15:31+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/index.php\/apps\/firstrunwizard\/wizard.php","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"ze2bvWiVi9TvUCYVjdMT","level":3,"time":"2024-02-14T06:15:31+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/license\/licenseMessage?app=core","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"WEuJ4dg1wNbjxJhmfSub","level":3,"time":"2024-02-14T06:22:32+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/license\/licenseMessage?app=core","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"lUzya6OMWymJ3M7Q17zY","level":3,"time":"2024-02-14T06:24:40+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/settings\/personal","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"4TDbMubyblAwSiD2rU4V","level":3,"time":"2024-02-14T06:24:41+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=0c4296af745ea40d3d08b95384bf30ad","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"esCVAT4CowwbmWGpiYH9","level":3,"time":"2024-02-14T06:24:41+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/license\/licenseMessage?app=core","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"kt7SciOw8QhyiiJ3jaaz","level":3,"time":"2024-02-14T06:24:53+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/settings\/admin?sectionid=general","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"yg6Z5zxoVVHXOOBgw0BF","level":3,"time":"2024-02-14T06:24:54+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=0c4296af745ea40d3d08b95384bf30ad","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"WMnPeuffD7xZUctwyOm2","level":3,"time":"2024-02-14T06:24:54+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/license\/licenseMessage?app=core","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"oHOgD4C1Vv8VVYOkI5r8","level":3,"time":"2024-02-14T06:25:05+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/apps\/configreport\/report","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"oHOgD4C1Vv8VVYOkI5r8","level":3,"time":"2024-02-14T06:25:08+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/apps\/configreport\/report","message":"phpinfo() has been disabled for security reasons at \/var\/www\/owncloud\/apps\/configreport\/lib\/ReportDataCollector.php#475"}
{"reqId":"Zw1c0LGX3ehpc8PYLJoR","level":3,"time":"2024-02-14T06:25:08+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/apps\/configreport\/report","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"Zw1c0LGX3ehpc8PYLJoR","level":3,"time":"2024-02-14T06:25:08+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/apps\/configreport\/report","message":"phpinfo() has been disabled for security reasons at \/var\/www\/owncloud\/apps\/configreport\/lib\/ReportDataCollector.php#475"}
{"reqId":"GJMVbu9zQ4JemVnhb8w5","level":3,"time":"2024-02-14T06:38:11+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=0c4296af745ea40d3d08b95384bf30ad","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"hWm9qCfigQZS4uIze82m","level":3,"time":"2024-02-14T06:38:12+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/license\/licenseMessage?app=core","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"rwdwMrw6G2KPPgYT0HQS","level":3,"time":"2024-02-14T06:38:29+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/license\/licenseMessage?app=core","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"T0kv2FJUL6dkWdektCrC","level":3,"time":"2024-02-14T06:38:33+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/settings\/personal","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"M0jFT00SObcRucT3m42Y","level":3,"time":"2024-02-14T06:38:34+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=0c4296af745ea40d3d08b95384bf30ad","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"i8DwTP4C2aMnRNIIt5Cw","level":3,"time":"2024-02-14T06:38:34+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/license\/licenseMessage?app=core","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"debMBbXGdZCaVSRIvTcv","level":3,"time":"2024-02-14T06:38:38+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/settings\/admin?sectionid=general","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"Ml25EGvKVXZacpHZJmp1","level":3,"time":"2024-02-14T06:38:39+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=0c4296af745ea40d3d08b95384bf30ad","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"LZOQMMbTwDFH3yPhaoWe","level":3,"time":"2024-02-14T06:38:39+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/license\/licenseMessage?app=core","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"GTZXSo0YxnZKCrSp3XFe","level":3,"time":"2024-02-14T06:39:03+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/settings\/admin?sectionid=general","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"4DJP9OWxO5wg3fgqds0V","level":3,"time":"2024-02-14T06:39:03+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=0c4296af745ea40d3d08b95384bf30ad","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
{"reqId":"gDELoFnCWuS9WMYifgZN","level":3,"time":"2024-02-14T06:39:03+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/license\/licenseMessage?app=core","message":"in_array() expects parameter 2 to be array, null given at \/var\/www\/owncloud\/lib\/private\/License\/BasicLicense.php#81"}
