Hello all.
I’m running owncloud in my intranet. When i try to log into my server with iOS app connected on my wifi I got the error “the internet connection appears to be offline”. If i switch the wifi off and I try to connect by using the VPN the app is able to log into the system. can you help me?
Is your server reachable out of the VPN? have you tried the web version to compare behaviours?
