Is it possible to specify where the instant upload is saved. Within ownCloud I have 2 primary directories, one being Photos, inside this is a directory for mobile photos.
I would ideally like the ownCloud app to place the files into the directory I choose rather than it forcing me to use a root directory.
If the answer is “no, you cant choose where to place it” then I can just create a script which will move the files.
