I did a few tests with the deployment example ocis-wopi.
It would be cool if only OnlyOffice was used, I find it confusing that both Office packages are started and used in the interface.
My first attempt was to comment out the containers ocis-appprovider-collabora and ocis-collabora in the docker-compose.yml file.
Unfortunately, no Office package is then displayed in oCIS.
I have not found anything in the wopi configurations.
I only changed the OpenOffice formats to OnlyOffice in the app-registry.yaml file of the ocis configuration.
I have also commented out the accesses to the Collabora URL in csp.yaml.
Unfortunately, OnlyOffice did not work in the web interface either.
Yes, you can use oCIS with OnlyOffice without Collabora. Ensure you update both app-registry.yaml and csp.yaml correctly, and configure wopi settings for OnlyOffice.Here are some ideas to get OnlyOffice working with oCIS without Collabora:
Update docker-compose.yml : Only keep ocis-appprovider-onlyoffice and remove ocis-appprovider-collabora.
Check app-registry.yaml and csp.yaml: Configure OnlyOffice URLs and formats correctly, then restart services.
