I have a question about the way server-side encryption works.
At the admin Panel I enabled server-side encryption. Also I enabled the App Default encryption module (1.1.0). The keys has been created and everything seems to work from the admin panel side.
But if I connect to my server, move to the owncloud directory I still can see and read all files. I also tried to create a my file by using the web interface or uploading a new file after enabling server-side encryption. But I can see the content without using any key.
What does sever-side encryption do if I can easily can read and edit all files? Does my server works the way it should ?
Is it possible that my old php version caused this issue, if it is one ?
System:
ownCloud 8.2.7 (stable)
Debian 7
PHP version (5.4.45-0+deb7u4)
