This version of ownCloud is not compatible with PHP 7.2
You are currently running 7.2.24-0ubuntu0.18.04.7.
what do i need to do
got into owncloud how do i fix this errors
PHP module dom not installed.
Please ask your server administrator to install the module.
PHP module XMLWriter not installed.
PHP module XMLReader not installed.
PHP module libxml not installed.
PHP module GD not installed.
PHP module SimpleXML not installed.
PHP module cURL not installed.
PHP modules have been installed, but they are still listed as missing?
Please ask your server administrator to restart the web server.
It seems that you are using an old owncloud version not compatible with the php 7.2 version.
You can install several versions of PHP and still use them with different webpages.
The following link may help you :
Hope this helps
that did not help me
what owncloud version are you using ?
You are installing an old version of ownCloud if it is incompatible with PHP 7.2. Do you have a good reason for this?
Otherwise please use the latest version.
dpkg -l | grep php to see which packages are installed.php -m to see which modules are enabledapt-get install <php module package name>.apt-cache search php | grep <module name>phpenmod <module name>systemctl restart apache2
