Unknown
Expected behaviour, in my opinion: either the groups are visible in the web interface, or the groups can be recreated.
After an upgrade of Owncloud server from 9.1.1 to 10.4.1, almost everything is working as expected, except for a relatively minor thing. There were a couple of groups used to assign permissions to certain folders within Owncloud. After the upgrade, these groups were no longer visible in the ‘Users’ section of the Owncloud web interface. However, the groups were still visible as groups under the ‘Sharing details’ of folders.
I tried removing the groups from ‘Sharing details’ in order to try recreating the groups, but I can’t: when I try to recreate the groups in Owncloud, I get an error that the groups already exist.
This instance of Owncloud has an LDAP connection to our environment’s Active Directory, where these groups exist. However, I’ve found no group:sync or command like that in the occ CLI. And running occ group:list doesn’t show the groups I’m missing, but which already exist according to Owncloud.
I would like to be able to manage or recreate the groups.
Operating system: Ubuntu 18.04.4 LTS
Web server: apache2
**Database:**mariaDB
PHP version: 7.2.24
ownCloud version: 10.4.1
Updated from an older ownCloud or fresh install: updated from ownCloud 9.1.1
Where did you install ownCloud from: unknown
Signing status (ownCloud 9.0 and above): unknown
paste the results into https://gist.github.com/ and put the link here.
Going to the above - but for this ownCloud instance - just gives: No errors have been found.
https://gist.github.com/RicardoAzuul/304b7329ecdb2cf8810df36502c6911b
Are you using encryption: unknown
Are you using an external user-backend, if yes which one: ActiveDirectory
