Issue with key update for user
Having an issue, tried both owncloud 10.1 and 10.3.2 with the same results.
User-encryption is enabled
Clients are LDAP users
When user’s LDAP password expires and they must change their password, they must update their key in owncloud.
I have a user that is trying to update their key, and getting stuck at “saving”
I have left the page up all night thinking it might take some time to run through the files but no luck.
Tried updating to 10.3 today and still an issue.
“system”: {
“updatechecker”: false,
“instanceid”: “REMOVED SENSITIVE VALUE”,
“trusted_domains”: [
“datadirectory”: “/var/www/owncloud/data”,
“overwrite.cli.url”: “https://owncloud.swau.edu”,
“dbtype”: “mysql”,
“version”: “10.3.2.2”,
“versions_retention_obligation”: “auto”,
“logtimezone”: “UTC”,
“installed”: true,
“mail_smtpmode”: “smtp”,
“ldapIgnoreNamingRules”: false,
“htaccess.RewriteBase”: “/”,
“maintenance”: false,
“loglevel”: 0,
“log_rotate_size”: 26214400,
“redis”: {
“host”: “localhost”,
“port”: 6379
“dbname”: “owncloud”,
“dbhost”: “127.0.0.1”,
“memcache.local”: “\OC\Memcache\APCu”,
“memcache.locking”: “\OC\Memcache\Redis”,
“filelocking.enabled”: “true”,
“singleuser”: false,
“theme”: “custom”,
“updater.secret”: “REMOVED SENSITIVE VALUE”
User about 30GB of files in his directory.
57%20PM
Have you checked the log files for errors? Is there anything interesting?
  • /path/to/owncloud/data/owncloud.log
  • /var/log/apache2/{access,error,other_vhosts_access}.log
  • /var/log/syslog
I’m pretty sure this is a server issue, if you could fill out the template for it, that would be much appreciated.
