Issues regarding public sharing after an update
I just updated Owncloud from the 10.1.1 version to owncloud-files 10.4.1-1 + 1.1 repository : http://download.owncloud.org/download/repositories/production/Debian_9.0/
Following this update, users tell me that they can no longer create public links in order to share resources with their students -but it works through the web browser with the Owncloud client.
When I click on “Create a public link”, nothing happens: the link works, but I can’t see any window popping up.
Debian GNU / Linux 9.12 (stretch)
mariadb-server-10.1
PHP 7.1.33-16 + 0
Thank you in advance for your answers.
hello !
In debug mode of my browser:
The application searches for OC.Share.ShareDialogExpirationView
While browsing the OC.Share object, we rather have ShareDialogLinkExpirationView …
2020-06-05 15_23_35-Courrier entrant - Crémos Mousli - Mozilla Thunderbird
There seems to be a problem updating JS library?
thank you in advance
Hello !
TypeError: OC.Share.ShareDialogExpirationView is not a constructor12 sharedialoglinkshareview.js:87:26
initialize sharedialoglinkshareview.js:87
Backbone 2
_showPopupForShare sharedialoglinklistview.js:200
onAddButtonClick sharedialoglinklistview.js:157
onAddButtonClick self-hosted:844
jQuery 2
Crémos
i can see a “/themes/dane” in the source code of your ownCloud installation. If this problem started after an update then i think it could be possible that this theme isn’t compatible with the newest ownCloud version.
Thank you for your return, this is very possible, can you change the theme?
I also have a message in the logs:
,“level”:3,“time”:“June 01, 2020 08:02:49”,“remoteAddr”:“86.192.42.36”,“user”:"–",“app”:“PHP”,“method”:“PROPFIND”,“url”:"/owncloud/remote.php/webdav/00-Coll%C3%A8ge%202019-2020",“message”:“Use of undefined constant \u2019dane\u2019 - assumed ‘\u2019dane\u2019’ at /var/www/owncloud/themes/dane/defaults.php#11”}
Again thank you for your clarification, I just changed the link theme: https://github.com/owncloud/theme-example and as if by magic the creation of public links works.
Thanks again.
cordially
i think this definitely looks like an incompatible theme responsible for your issue. I’m not sure how to disable it as i never have used any theme but i think you could find any options for this in the admin backend of ownCloud.
I downloaded a theme and then copied to / var / www / owncloud / themes
To activate the theme we will modify the following conf file:
nano /var/www/owncloud/config/config.php
We will add or modify the following parameter:
‘Theme’ => ‘nomdutheme’,
We record then,
Thanks again
