Issues with ownCloud 4.4.0-beta.1 - Database Sync Fails Randomly
Hey everyone,
I recently upgraded to ownCloud 4.4.0-beta.1 to test out the new features, but I’ve been running into a weird issue. The database sync seems to fail randomly, especially when handling large files. I’ve tried tweaking the config file and even reinstalled the beta version, but no luck so far. Has anyone else encountered this problem? Is this a known bug, or am I missing something in the setup? Any advice or workarounds would be greatly appreciated!
by [Wishforbes]
@wishforbes thanks for reporting. This issue is not know and not expected. Was the behaviour correct with 4.3.1 (our latest stable)? 4.4.0-beta.1 does not include new stuff regarding files handling. Do you have that problem while browsing? or when any operation is done?
another questions @wishforbes:
  • What do you mean with “the database sync seems to fail”? which database? how do you know the database fails?
  • What do you mean with “tweaking the config file”? which file? which tweak?
this info will help us to understand better the problem you described.
