- Mount external owncloud storage
- Trying to reshare the mounted external storage from the mounting owncloud
- HTTPS mount is not possible at all
- Reshareing subdirectories on the external storage should be shareable, and therefor available for the other users they are being shared with.
- HTTPS should be mountable
- The share icon does not appear and a “Pending” notification is showing up on the mounted store for every directory.
- HTTPS always gives errors, when mounted even with imported certificates (Let’s Encrypt) it just opens a file and the external storage view shows no permission to access.
Linux Owncloud Appliance and Gentoo
Apache / Docker-Apache
MySQL
7.x
10.0.2
Updated 8 -> 9 -> 10
tar.gz, Docker
Technical information
them.
Results
- core
- EXTRA_FILE
- lib/composer/natxet/CssMin/src/CssMin.php
- lib/composer/natxet/CssMin/composer.json
- lib/composer/natxet/CssMin/README
- core/doc/admin/_sources/configuration/server/js_css_asset_management_configuration.rst.txt
- core/doc/admin/_sources/configuration/server/security/ransomware-protection.rst.txt
- core/doc/admin/configuration/server/js_css_asset_management_configuration.html
- core/doc/admin/configuration/server/security/ransomware-protection.html
- files_external
- EXTRA_FILE
- 3rdparty/Dropbox/OAuth.php
- 3rdparty/Dropbox/API.php
- 3rdparty/Dropbox/autoload.php
- 3rdparty/Dropbox/OAuth/PEAR.php
- 3rdparty/Dropbox/OAuth/Curl.php
- 3rdparty/Dropbox/OAuth/PHP.php
- 3rdparty/Dropbox/OAuth/Wordpress.php
- 3rdparty/Dropbox/OAuth/Zend.php
- 3rdparty/Dropbox/OAuth/ca-bundle.pem
- 3rdparty/Dropbox/OAuth/Consumer/Dropbox.php
- 3rdparty/Dropbox/Exception.php
- 3rdparty/Dropbox/Exception/Forbidden.php
- 3rdparty/Dropbox/Exception/RequestToken.php
- 3rdparty/Dropbox/Exception/NotFound.php
- 3rdparty/Dropbox/Exception/OverQuota.php
- lib/Lib/Backend/Dropbox.php
- lib/Lib/Storage/Dropbox.php
- js/dropbox.js
- ajax/oauth1.php
- templateeditor
- EXTRA_FILE
- controller/adminsettingscontroller.php
- http/mailtemplateresponse.php
- lib/adminpanel.php
- lib/mailtemplate.php
- app/templateeditor.php
Raw output
Array
[core] => Array
[EXTRA_FILE] => Array
[lib/composer/natxet/CssMin/src/CssMin.php] => Array
[expected] =>
[current] => 3dbb09114c95f76781d9facc76b2d479c1e9776bf7d63da5a09078f9433897eb1ae6fca84f8569ac40bd5a3cd08c4d828316136cc7ede47d95d73552be02a042
[lib/composer/natxet/CssMin/composer.json] => Array
[expected] =>
[current] => 2849b139201f7844eaad998314cf5069455c00cfdf16cf3e53d8496922ddbc8f5cf12f6b9180be216d0631f37b17e98c05de17a990da7601b4efb7c4ebec3bd3
[lib/composer/natxet/CssMin/README] => Array
[expected] =>
[current] => fe9af7fa554d602f03964eb267863ecb332f1e8ccebc8f35e8798a9637c6ff139f05a0ff12679b0d5dbcd4455eb67786d1f1682cef2d041c36537f92d0a3f600
[core/doc/admin/_sources/configuration/server/js_css_asset_management_configuration.rst.txt] => Array
[expected] =>
[current] => 956ace6e39af1141c30207f8de8bc6abf09de3c63908b186dcf23060a455dc1c67c243bc49aa13e362ef467bdb8dab7c569ac53395c167bad262c235279b790f
[core/doc/admin/_sources/configuration/server/security/ransomware-protection.rst.txt] => Array
[expected] =>
[current] => e68e0ebb933b302610b64b3a812b286b71536d222e7fe01e678f53560b9d8c4337423ab2dd887276232175f5bd8876a77792709536bff92ca2766ad3b7efb9c6
[core/doc/admin/configuration/server/js_css_asset_management_configuration.html] => Array
[expected] =>
[current] => ff1a7b190add7344103c3489c5b8a16dded1c8b22125d216cfb948898ec17c5d4904ffdad57da4d198e4acfe6952de213c877a29e1af25cb70ebb16c3011f2b4
[core/doc/admin/configuration/server/security/ransomware-protection.html] => Array
[expected] =>
[current] => 3dde7b6c014b18923304664532cdecc818110637c26959872d6be09e634d2d4d3d518a5830afdaad379bc1b11a58a9fecf05855b3734d0016891dd3b59e34e37
[files_external] => Array
[3rdparty/Dropbox/OAuth.php] => Array
[expected] =>
[current] => cc1af021373e74c5a0531b81240740e11d88bad38890155a1ac41e875cb26e35e1eb0a08153454bf96eae27b3a34f600fafa76b58d85553b6604a5358954bbde
[3rdparty/Dropbox/API.php] => Array
[expected] =>
[current] => a6866ef3ceeb26d9d4b2ccc343aeaf626c82f03e279962bc7d761a68e87e5a7916ff0bcf7a350e20889557336ed9c5dd1651cfe513fa04bb8a03cd6d8f9cc484
[3rdparty/Dropbox/autoload.php] => Array
[expected] =>
[current] => 7f831eb7adb5343ff9790428b51a62ce94b1c34385fec7984e45afbf54cf55119650772045ac6f7409d15582e07152ace6d64f3dae5a9a9281e9ee0714b9d5b7
[3rdparty/Dropbox/OAuth/PEAR.php] => Array
[expected] =>
[current] => 5d11f888cda6871139a76dcbee9a5856a75706fad54a8152ff1ea6b8a207ba959e2c2ebab9e8aa6635ad523d8846ba2d15d8fdf9e52459a02201b3b31735b25b
[3rdparty/Dropbox/OAuth/Curl.php] => Array
[expected] =>
[current] => fd22aca4aec936b6b81693bc67738e08a0110720c471059ed0240568451b18f51fc79bb9619d81b9ace9161775fe2d01d81a2adfdda43986090d7e6b02a1c10f
[3rdparty/Dropbox/OAuth/PHP.php] => Array
[expected] =>
[current] => 225553fde870e8bccaf98e52ff61a28da323ca17383a474c096394babd943601e07caa4658fbcd01b0c8ac1396c4c9ae1b79c3c472c1683d0b8b3bc5f115063a
[3rdparty/Dropbox/OAuth/Wordpress.php] => Array
[expected] =>
[current] => 1b1fd11e0753b9dc0b0b5393d0618896052bb48115c2ac09640c66157aa3848d52a1779de23cdcd98d37d8596be5403edb6891998bfa2cabdc2a05a713742c4f
[3rdparty/Dropbox/OAuth/Zend.php] => Array
[expected] =>
[current] => 108bfc910b5258a328fdd1ef12b99ae94cceb4f3a785770f15b89564e0f326fd86dda3593f085dfa1dd37ad78547ae5f7c788979d6c9843975b4dced9111cacf
[3rdparty/Dropbox/OAuth/ca-bundle.pem] => Array
[expected] =>
[current] => 90f17bf35259a2a3e385d7bfcf4d0244bd94b572835864c33f6a2f30651445373cf5840e5f811ae8c3914e2fcaab63c36bfc5d49d75ad9f37fdf682e6dd6e847
[3rdparty/Dropbox/OAuth/Consumer/Dropbox.php] => Array
[expected] =>
[current] => bc98245ac1623cba9fe963b87190f3cec24832e7fd578808b494c6433dcaf2381ebf49f9a557d99c7ed30cc4f4c368ae71701f0a3ee0deadfabc61ef4ac55ee4
[3rdparty/Dropbox/Exception.php] => Array
[expected] =>
[current] => 013f5ad46c6e74bce445883428f038e988d0389b4bfece7223a65210bb7ef5464dc7078aedf294671450fedb819980e8caef4ff499a3d1e78529b6b746b39d7e
[3rdparty/Dropbox/Exception/Forbidden.php] => Array
[expected] =>
[current] => 886cc399ff1b940d9b51032589f2900473c99c617bcd2b1d6aa0fb053abbaf28e1d825556d1a19682324b276015356d96388ad85656308670cb4d083a603c674
[3rdparty/Dropbox/Exception/RequestToken.php] => Array
[expected] =>
[current] => 613259eaa4ffe6c2618917dc37bbdc0551bd4034f2d43d581ec9a2024ec3dc7d31490f6a9cc970b02d4456358fa1c587f7afb420950434ebbed9d5a1df20d0a4
[3rdparty/Dropbox/Exception/NotFound.php] => Array
[expected] =>
[current] => 96ab235b2bc835f60fbb996d390613df31866fe827b995c4d3348043313142851d44c36c8ebec93ed30f8488dc13e0a4e894fa1f57bc4e7c52effe13aec62a93
[3rdparty/Dropbox/Exception/OverQuota.php] => Array
[expected] =>
[current] => cb8cec67ba77427dd1d56f63a3f27ec1e8ed271cbff39872d7caefe950b2d6d3ddec426380ae8135f9bc0df7dc04cf9e746e032812cf91a2f9f3991e0924c295
[lib/Lib/Backend/Dropbox.php] => Array
[expected] =>
[current] => 90a7d702f8ca21a786b1918a63f37ef0cd9bc28ae6579ca6f3c9b9b197841005ccb96bfc449872d72933001bdf05e221d447fb4370f8a9030c7bb1190992dbfd
[lib/Lib/Storage/Dropbox.php] => Array
[expected] =>
[current] => 4ea3dda86d2f6f75fed295b508be447a8d93cf425c107010cb060ec7845e6b5f2957db09c4d32c6c718257ffe039a042b114cc9b08e8a879e2c5ed7db8844f01
[js/dropbox.js] => Array
[expected] =>
[current] => 1ac657c202d387f2cb99c4652241a82efb735b7c6ff3f0ee571c8207c7217d9d40431037afa8eb04d2560742edc9228292dc5c5668d21244edf49d7696731dd8
[ajax/oauth1.php] => Array
[expected] =>
[current] => c302d7cd9ff1d43807116c555013facd4628db3fb763668372da68996ae407fcf3334edc8d599f097ac605f4fbe203fbce2fdac9c010c9311f61110e03ab603f
[templateeditor] => Array
[controller/adminsettingscontroller.php] => Array
[expected] =>
[current] => 8dea5e7bdf423cfda892d68791859beaa689b45a5ccee4d46e4c7937d06777ad9f766c98c29995dae6a2ec370b34601043f18180123e2f69ae3a116637fafc1c
[http/mailtemplateresponse.php] => Array
[expected] =>
[current] => e09a5dfd9bc719ea04c1876fae94fd539b060ba8b1a9a01e043002defca53861678bc14f3b625c376546cc9aa5135528031696530017036d2337459aa876cc42
[lib/adminpanel.php] => Array
[expected] =>
[current] => c4eaf76cdd3b4eacd55ee599975b31e689be142237ee148be4b80e61527326a5876d4e28e3c2fdb8f43e43cfbe43b5c04bb567e3492357ad090c680b56024ca8
[lib/mailtemplate.php] => Array
[expected] =>
[current] => 0a1e1859940f929f45a94f8280a2daf6f924be4e1ea82fdc6dbb59e12fb8aaf8075d66c9cb04ef40928636d16424861ae9b08440354b009115e8662753e4ca14
[app/templateeditor.php] => Array
[expected] =>
[current] => 36ad0ed56162c9e4fc571daf1947081687a80b565e5137202e2f7eab06d6431329bdeec18c54bb2949e59965115177319417a6df765e81f0ebc40d5b69b146c3
