Issues with public links
  1. Enable external storage and add a local path
  2. Add data to local storage
  3. Create public links and share It
The user with the link could be able to download data
The browser starts downloading a “download.zip” file with a size of 10kb if try to download the entire folder. If try to download a single file, the browser show the message “impossible to download the file”
Ubuntu 24.04 on WSL2 under Windows 11
apache2 -v
Server version: Apache/2.4.58 (Ubuntu)
Server built: 2024-07-17T18:55:23
mysql -v
Welcome to the MariaDB monitor. Commands end with ; or \g.
Your MariaDB connection id is 244
Server version: 10.11.8-MariaDB-0ubuntu0.24.04.1 Ubuntu 24.04
$ php -v
PHP 7.4.33 (cli) (built: Sep 27 2024 04:14:06) ( NTS )
10.15.0.2
Fresh
Manual install
Enabled:
  • activity:
    • Version: 2.7.2
    • Path: /var/www/owncloud/apps-external/activity
  • comments:
    • Version: 0.3.0
    • Path: /var/www/owncloud/apps/comments
  • configreport:
    • Version: 0.3.0
    • Path: /var/www/owncloud/apps/configreport
  • dav:
    • Version: 0.7.0
    • Path: /var/www/owncloud/apps/dav
  • encryption:
    • Version: 1.6.1
    • Path: /var/www/owncloud/apps/encryption
  • federatedfilesharing:
    • Version: 0.5.0
    • Path: /var/www/owncloud/apps/federatedfilesharing
  • federation:
    • Version: 0.1.0
    • Path: /var/www/owncloud/apps/federation
  • files:
    • Version: 1.6.0
    • Path: /var/www/owncloud/apps/files
  • files_clipboard:
    • Version: 1.0.3
    • Path: /var/www/owncloud/apps-external/files_clipboard
  • files_external:
    • Version: 0.9.0
    • Path: /var/www/owncloud/apps/files_external
  • files_external_dropbox:
    • Version: 2.0.2
    • Path: /var/www/owncloud/apps-external/files_external_dropbox
  • files_external_ftp:
    • Version: 0.2.1
    • Path: /var/www/owncloud/apps-external/files_external_ftp
  • files_mediaviewer:
    • Version: 1.0.5
    • Path: /var/www/owncloud/apps/files_mediaviewer
  • files_pdfviewer:
    • Version: 1.0.2
    • Path: /var/www/owncloud/apps-external/files_pdfviewer
  • files_sharing:
    • Version: 0.14.0
    • Path: /var/www/owncloud/apps/files_sharing
  • files_trashbin:
    • Version: 0.9.1
    • Path: /var/www/owncloud/apps/files_trashbin
  • files_versions:
    • Version: 1.3.0
    • Path: /var/www/owncloud/apps/files_versions
  • firstrunwizard:
    • Version: 1.3.0
    • Path: /var/www/owncloud/apps/firstrunwizard
  • market:
    • Version: 0.9.0
    • Path: /var/www/owncloud/apps/market
  • notifications:
    • Version: 0.6.0
    • Path: /var/www/owncloud/apps/notifications
  • provisioning_api:
    • Version: 0.5.0
    • Path: /var/www/owncloud/apps/provisioning_api
  • systemtags:
    • Version: 0.3.0
    • Path: /var/www/owncloud/apps/systemtags
  • updatenotification:
    • Version: 0.2.1
    • Path: /var/www/owncloud/apps/updatenotification
      Disabled:
  • external:
    • Path: /var/www/owncloud/apps/external
  • user_external:
    • Path: /var/www/owncloud/apps/user_external
Local
yes
NO
Firefox
Windows 11
no webserver error log
{“reqId”:“Z7L3xSO0LU1EMqOjExyZCQAAAAs”,“level”:3,“time”:“2025-02-17T08:48:05+00:00”,“remoteAddr”:“192.71.XXX.XXX”,“user”:“–”,“app”:“no app in context”,“method”:“GET”,“url”:“/owncloud/index.php/s/d8wV3okjQGZQR5e/download?path=%2F&files=48.tif&downloadStartSecret=7dtzwzgxy7r”,“message”:“Exception: {"Exception":"OC\\User\\NoUserException","Message":"Attempted to initialize mount points for null user and no user in session","Code":0,"Trace":"#0 \/var\/www\/owncloud\/lib\/private\/Encryption\/Keys\/Storage.php(383): OC\\Files\\Filesystem::initMountPoints()\n#1 \/var\/www\/owncloud\/lib\/private\/Encryption\/Keys\/Storage.php(283): OC\\Encryption\\Keys\\Storage->setupUserMounts()\n#2 \/var\/www\/owncloud\/lib\/private\/Encryption\/Keys\/Storage.php(93): OC\\Encryption\\Keys\\Storage->getFileKeyDir()\n#3 \/var\/www\/owncloud\/apps\/encryption\/lib\/KeyManager.php(404): OC\\Encryption\\Keys\\Storage->getFileKey()\n#4 \/var\/www\/owncloud\/apps\/encryption\/lib\/Crypto\/Encryption.php(498): OCA\\Encryption\\KeyManager->getFileKey()\n#5 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Encryption.php(365): OCA\\Encryption\\Crypto\\Encryption->isReadable()\n#6 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php(177): OC\\Files\\Storage\\Wrapper\\Encryption->isReadable()\n#7 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php(177): OC\\Files\\Storage\\Wrapper\\Wrapper->isReadable()\n#8 \/var\/www\/owncloud\/lib\/private\/Files\/View.php(1225): OC\\Files\\Storage\\Wrapper\\Wrapper->isReadable()\n#9 \/var\/www\/owncloud\/lib\/private\/Files\/View.php(535): OC\\Files\\View->basicOperation()\n#10 \/var\/www\/owncloud\/lib\/private\/Files\/Filesystem.php(841): OC\\Files\\View->isReadable()\n#11 \/var\/www\/owncloud\/lib\/private\/legacy\/files.php(282): OC\\Files\\Filesystem::isReadable()\n#12 \/var\/www\/owncloud\/lib\/private\/legacy\/files.php(124): OC_Files::getSingleFile()\n#13 \/var\/www\/owncloud\/apps\/files_sharing\/lib\/Controllers\/ShareController.php(557): OC_Files::get()\n#14 \/var\/www\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(169): OCA\\Files_Sharing\\Controllers\\ShareController->downloadShare()\n#15 \/var\/www\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(89): OC\\AppFramework\\Http\\Dispatcher->executeController()\n#16 \/var\/www\/owncloud\/lib\/private\/AppFramework\/App.php(99): OC\\AppFramework\\Http\\Dispatcher->dispatch()\n#17 \/var\/www\/owncloud\/lib\/public\/AppFramework\/App.php(131): OC\\AppFramework\\App::main()\n#18 \/var\/www\/owncloud\/core\/routes.php(145): OCP\\AppFramework\\App->dispatch()\n#19 \/var\/www\/owncloud\/lib\/private\/Route\/Router.php(344): OC\\Route\\Router->{closure}(*** sensitive parameters replaced ***)\n#20 \/var\/www\/owncloud\/lib\/kernel.php(925): OC\\Route\\Router->match()\n#21 \/var\/www\/owncloud\/index.php(32): OC::handleRequest()\n#22 {main}","File":"\/var\/www\/owncloud\/lib\/private\/Files\/Filesystem.php","Line":396}”}
JQMIGRATE: Migrate is installed, version 1.4.0
shareconfigmodel.js?v=7ad8d2b568daf32f5084386b0715415d:24 Uncaught ReferenceError: oc_appconfig is not defined
at shareconfigmodel.js?v=7ad8d2b568daf32f5084386b0715415d:24:33
at shareconfigmodel.js?v=7ad8d2b568daf32f5084386b0715415d:212:3
(anonimo) @ shareconfigmodel.js?v=7ad8d2b568daf32f5084386b0715415d:24
(anonimo) @ shareconfigmodel.js?v=7ad8d2b568daf32f5084386b0715415d:212
files_mediaviewer_init.js?v=7ad8d2b568daf32f5084386b0715415d:1 Uncaught TypeError: Cannot read properties of undefined (reading ‘enabledPreviewProviders’)
at 473 (files_mediaviewer_init.js?v=7ad8d2b568daf32f5084386b0715415d:1:115)
at r (files_mediaviewer_init.js?v=7ad8d2b568daf32f5084386b0715415d:1:1585)
at files_mediaviewer_init.js?v=7ad8d2b568daf32f5084386b0715415d:1:1823
at files_mediaviewer_init.js?v=7ad8d2b568daf32f5084386b0715415d:1:2536
473 @ files_mediaviewer_init.js?v=7ad8d2b568daf32f5084386b0715415d:1
r @ files_mediaviewer_init.js?v=7ad8d2b568daf32f5084386b0715415d:1
(anonimo) @ files_mediaviewer_init.js?v=7ad8d2b568daf32f5084386b0715415d:1
Hello, why did you reposted my comment?
Thank you
