I connect to the admin panel for external storage YandexDisk (WebDAV). Gets green light:
But when I want to open a storage folder, I get an error «Storage not available»
Ubuntu 16.04, OC 9.1.2
Log file Fatal (webdav):
Exception: {“Message”:“HTTP/1.1 503 Storage not available”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(903): OCA\DAV\Connector\Sabre\ObjectTree->getNodeForPath(‘Yandex’)\n#1 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(334): Sabre\DAV\Server->getPropertiesForPath(‘Yandex’, Array, 1)\n#2 [internal function]: Sabre\DAV\CorePlugin->httpPropFind(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#3 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#4 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:PROPFIND’, Array)\n#5 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#6 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#7 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#8 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/ObjectTree.php”,“Line”:159,“User”:“admin”}
