Initially I though this issue was file size > 512mb but after following instructions for increasing filesize (2G) in php.ini I get no change and anyhow I see small files ~kb are impacted too. After increasing server log to debug I don’t see any relevant signs in the logs pointing keywords like ‘blacklist’, the file names, timestamps etc.
I’ve tried reinstalling oc-client, removing adding folders, force resync, using server occ files repair and restarting apache, server and oc-client.
At this stage, since I don’t want to wait 24hours each time I tweak a setting, I’d like to be able to see/edit the list of blacklisted files as referred to in the oc-client logs, how can I do this or can anyone hint at root cause?
thanks
Andrew
All files should sync normally or when forced.
A few files are reported (various sizes and various folders)
- normal oc-client day-to-day wrk
- add some files
- see errors in oc-client UI under activity showing 4 or 5 files with issue shown as ‘error transferring… server replied : (skipped due to earlier error trying again in X hrs)’
Operating system: Raspbian stretch
Web server: Apache/2.4.25 (Raspbian)
Database: 10.1.38-MariaDB-0+deb9u1 - Raspbian 9.0
PHP version: PHP version:7.2.26-1+0~20191218.33+debian9~1.gbpb5a34b
ownCloud version: 10.2.1.4
Client version: Version 2.5.1.10973+dfsg-1ubuntu2.
Operating system: Ubuntu 19.04
OS language: En
Installation path of client:
- Client logfile: Output of
owncloud --logwindoworowncloud --logfile log.txt
extract relevant chunk from owncloud-client log
| 01-14 13:19:41:302 [ warning sync.propagator ]: | Could not complete propagation of “Documents/jobs/Peaky.Blinders.S03E02.720p.BluRay.x264-GalaxyTV.mkv” by OCC::PropagateIgnoreJob(0x55ec42dfe080) with status 9 and error: “Error transferring https://awsbarker.ddns.net/owncloud/remote.php/dav/uploads/Andrew/1856036348/00000000 - server replied: (skipped due to earlier error, trying again in 22 hour(s))” |
| 01-14 13:19:47:899 [ info sync.csync.updater ]: | file: ValueWorkshop/Bridges To Prosperity - Overview-OB2Lwu5MVp0.mkv, instruction: INSTRUCTION_NONE <<= |
| 01-14 13:19:49:172 [ info sync.csync.updater ]: | file: Documents/jobs/Peaky.Blinders.S03E02.720p.BluRay.x264-GalaxyTV.mkv, instruction: INSTRUCTION_NEW <<= |
| 01-14 13:19:49:401 [ info sync.csync.updater ]: | file: vdo2g0/Peaky.Blinders.S03E02.720p.BluRay.x264-GalaxyTV.mkv, instruction: INSTRUCTION_NEW <<= |
| 01-14 13:19:52:164 [ info sync.csync.reconciler ]: | INSTRUCTION_NEW client file: Documents/jobs/Peaky.Blinders.S03E02.720p.BluRay.x264-GalaxyTV.mkv |
| 01-14 13:19:52:167 [ info sync.csync.reconciler ]: | INSTRUCTION_NEW client file: vdo2g0/Peaky.Blinders.S03E02.720p.BluRay.x264-GalaxyTV.mkv |
| 01-14 13:19:52:189 [ info sync.engine ]: | Item is on blacklist: “Documents/jobs/Peaky.Blinders.S03E02.720p.BluRay.x264-GalaxyTV.mkv” retries: 1 for another 79352 s |
| 01-14 13:19:52:195 [ info sync.engine ]: | Item is on blacklist: “vdo2g0/Peaky.Blinders.S03E02.720p.BluRay.x264-GalaxyTV.mkv” retries: 1 for another 79353 s |
| 01-14 13:19:52:272 [ info sync.propagator ]: | Starting INSTRUCTION_IGNORE propagation of “Documents/jobs/Peaky.Blinders.S03E02.720p.BluRay.x264-GalaxyTV.mkv” by OCC::Pro |
- Web server error log:
When I grep the server log for keywords from above no output despite level being 0 debug. If I look arounf the above error timestamp I can only see this as unusual
{“reqId”:“FgtX5kSCexlUhthqlllb”,“level”:3,“time”:“2019-08-10T13:19:15+02:00”,“remoteAddr”:"",“user”:"–",“app”:“PHP”,“method”:"–",“url”:"–",“message”:“You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/owncloud/lib/composer/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18”}
{“reqId”:“sWp8y3aavkhKlffgVPYJ”,“level”:3,“time”:“2019-08-10T13:19:52+02:00”,“remoteAddr”:"",“user”:"–",“app”:“PHP”,“method”:"–",“url”:"–",“message”:“You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/owncloud/lib/composer/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18”}
{“reqId”:“t2O6ORKnszPFdJHceIrc”,“level”:3,“time”:“2019-08-10T13:19:59+02:00”,“remoteAddr”:"",“user”:"–",“app”:“PHP”,“method”:"–",“url”:"–",“message”:“You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/owncloud/lib/composer/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18”}
{“reqId”:“eae95961-72b6-42f2-b76b-6680d2e3471d”,“level”:4,“time”:“2019-08-10T16:13:19+02:00”,“remoteAddr”:“192.168.1.105”,“user”:"–",“app”:“remote”,“method”:“GET”,“url”:"/owncloud/status.php",“message”:“Memcache \OC\Memcache\APCu not available for local cache”}
{“reqId”:“eae95961-72b6-42f2-b76b-6680d2e3471d”,“level”:3,“time”:“2019-08-10T16:13:19+02:00”,“remoteAddr”:“192.168.1.105”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/status.php",“message”:“You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/owncloud/lib/composer/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18”}
- Server logfile: ownCloud log (data/owncloud.log):
