I uploaded the setup-owncloud.php on my free webhosting(000webhost). And I followed the steps and made a clean installation. But after that, the owncloud keeps restarting from 5 to 5 seconds continously in a loop.
“Problem loading page, reloading in 5 seconds”
How can I fix this?
Please have a look below at the attached pictures.
Also this is how my installation step looked like:
According your 2nd pic, you have selected SQLite. Not sure this is available there, but MySQL is. Try to change this.
I did,I connected to mysql db from my hosting website, still same message, same issue.
PS: I am using php 7.1 tried with 5.6 and still same issues
where exactly to check can you specify exactly please?
There are no log files in my public html, and on the owncloud website, I can’t do barely anything aside from accessing settings, as below:
All my warnings and errors are in the below log:
How to fix ?
I put at the installation my db, but the ownclouds thinks he is using sqlite.
What port to use when installing owncloud? I mean when inputting the database in localhost field
localhost:What port?
When I installed now, the last field of installation on localhost I let it just localhost without putting port
What do you think it might be the cause for constant rebooting-loop of the page?
Now I get this error, I am using MYSQL db, but it keeps restarting the page in an infinite loop from 5 to 5 seconds
I am running a Windows 7 PC, and my free hosting website is 000webhost with php 7.1, mysql and cpanel
The logfile of ownCloud is located in the data directory /var/www/owncloud/data/owncloud.log.
This is my log from the location you specified:
And this is the status in my settings, the restart loop of the website after 5 seconds still continues, how can I fix it?
alfredb
August 14, 2017, 10:17am
11
According the forum at 000webhost.com , it should be possible ti install.
https://www.000webhost.com/forum/t/how-to-install-owncloud/49336
BTW, opening a new topic for the same, unsolved problem should be avoided.
Yeah, I followed the steps, , I did exactly the same, clean install, still same issue.
I tried other way,I downloaded owncloud setup .php from here https://download.owncloud.com/download/community/setup-owncloud.php , uploaded on the website, did the installation correctly and still get the same error with restart loop every 5 seconds.
This is the errors that I get
How to fix them?
