I am still not successful with my OCIS 4.x deployment and would need some debugging assistance from folks running a similar setup. The docs at
and elsewhere were not helpful in my case. My general setup/environment:
- haproxy as reverse proxy
- running IDP (current keycloak)
- productive OC 10 is already linked to the IDP
- haproxy, IDP and OC 10 are running as “virtualized bare metal” in separate lxc containers (Proxmox VE)
- ocis 4. in separate lxc container
Attached ocis.env (renamed to txt) is loaded within systemd’s ocis.service file:
ocis.txt (1,3 KB)
Logfile:
{"level":"debug","service":"proxy","jwks":"https://login.netzwissen.de/realms/netzwissen/protocol/openid-connect/certs","time":"2024-03-15T18:45:00.671954679Z","line":"github.com/owncloud/ocis/v2/ocis-pkg/oidc/client.go:156","message":"discovered jwks endpoint"}
{"level":"debug","service":"proxy","access token":{"sid":"436e899f-d212-4cf4-9a56-284f46adf144","iss":"https://login.netzwissen.de/realms/netzwissen","sub":"baacc53c-937d-4256-8b1d-c2f301bba374","aud":["realm-management","account"],"exp":1710557090,"iat":1710528291,"jti":"238a6cb3-8317-4f69-94bf-87e7781b5208"},"time":"2024-03-15T18:45:00.676651025Z","line":"github.com/owncloud/ocis/v2/ocis-pkg/oidc/client.go:305","message":"parsed access token"}
{"level":"debug","service":"proxy","claims":{"allowed-origins":["https://ocis.netzwissen.de"],"aud":["realm-management","account"],"auth_time":1710528290,"azp":"ocis-web","email":"admin@netzwissen.de","email_verified":true,"exp":1710557090,"family_name":"realm admin","given_name":"admin netzwissen","iat":1710528291,"iss":"https://login.netzwissen.de/realms/netzwissen","jti":"238a6cb3-8317-4f69-94bf-87e7781b5208","locale":"de","name":"admin netzwissen realm admin","preferred_username":"admin","realm_access":{"roles":["ocisSpaceAdmin","default-roles-netzwissen","offline_access","uma_authorization","ocisUser","ocisAdmin"]},"resource_access":{"account":{"roles":["manage-account","manage-account-links","view-profile"]},"realm-management":{"roles":["manage-events"]}},"scope":"openid profile email","session_state":"436e899f-d212-4cf4-9a56-284f46adf144","sid":"436e899f-d212-4cf4-9a56-284f46adf144","sub":"baacc53c-937d-4256-8b1d-c2f301bba374","typ":"Bearer"},"time":"2024-03-15T18:45:00.680883609Z","line":"github.com/owncloud/ocis/v2/services/proxy/pkg/middleware/oidc_auth.go:123","message":"extracted claims"}
{"level":"info","service":"auth-machine","pkg":"rgrpc","traceid":"03f39ba194e5df6801b1214604199887","time":"2024-03-15T18:45:00.732536454Z","line":"github.com/cs3org/reva/v2@v2.16.1/internal/grpc/services/authprovider/authprovider.go:141","message":"user idp:\"https://login.netzwissen.de/realms/netzwissen\" opaque_id:\"429fe5b5-6f7e-4500-9012-b57a205d9461\" type:USER_TYPE_PRIMARY authenticated"}
The admin user in the ocis.yaml created through
sudo -u ocis ocis init --admin-password=xxxxxxxxx --insecure=false --config-path=/etc/ocis
has the same credentials like the admin user in IDP realm, its also visible in the ocis.yaml. So I would expect the login should be successful. I dont understand whats happening here …
