Hi, there.
I run owncloud since about 1 year now. The setup was already quiet demanding but it worked like a charm until recently when I had to setup my new Notebook.
I am using Outlook 2016 with the Comodo, OutlookDAV sync client.
The sync of the Contacts worked nicely after setting up the client but the calendar always gives me some faults. I used exactly the same data as in my previous installation on the old Notebook.
What kind of files would you guys need to help me with this?
Thank you for your understanding that I have no idea whow this Server thing works. So please try to make it simple.
Thank you.
Peter
Please help us by providing the following info. Before posting please make sure that you're running the latest available version for your oC release: https://owncloud.org/changelog/ + https://owncloud.org/changelog/desktop/
2.
3.
Synch of CalDAV and CardDAV between my Phones, Notebook and the Server
worked well for the last 12 month and out of a sudden, with the new Notebook and the same Login and CalDAV path like before there is no sync anymore. CardDAV works like before, only CalDAV sync shows problems. Failure Logs can beprovided.
Windows 10 with Office 2016 Pro
Comodo OutlookDAV 6.4
Client version:
Client operating system:
Database-Server
Server: Localhost via UNIX socket
Server-Typ: MariaDB
Server-Version: 5.5.52-MariaDB - Source distribution
Protokoll-Version: 10
Benutzer: root@localhost
Server-Zeichensatz: UTF-8 Unicode (utf8)
Webserver
nginx/1.10.1
Datenbank-Client Version: libmysql - mysqlnd 5.0.11-dev - 20120503 - $Id: 76b08b24596e12d4553bd41fc93cccd5bac2fe7a $
PHP-Erweiterung: mysqliDokumentation curlDokumentation mbstringDokumentation
PHP-Version: 5.6.23
ownCloud version (see ownCloud admin page):8.2.2
