Kindly seeking insight of In-place upgrade owncloud 10.7 to 10.14
hi Community
hope this email finds you all well..
just wanted to check if a direct in-place application upgrade is possible from 10.7 to 10.14
or is it better to do a out-of-place upgrade (install new OS and owncloud 14 than migrate application config, user application data and finally mariadb migration
An upgrade to the latest version works, if I recall correctly with everything after 9.2 or so …
thank you @hodyroff for your insightful experience and sharing it with me…
much appreciated…
God Bless
it seems that the ownCloud people are also providing upgrade instructions in the documentation below and i think this confirms that you should be able to easily update from ownCloud 10.7.0 to 10.14.0:
From my experiences the manual upgrade always worked for me:
