Larger virtual box partition
#1
I got everything to work, at least I was able to get to my cloud via web, and I was able to upload files. However I realized after I ran the virtual box appliance, I had only allotted 50G to my partition. Can I just add space without rebuilding the virtual box, or do i need to start from scratch?
Thanks,
/3db
Strip down amount of categories?
#2
i think the post below could be valid here as well:
#3
It sounds like it would be easier to just start from scratch. Is that something that I can do? It took a very long time for it to get it to this part and i’d hate to rebuild the appliance just to find out that it’s not possible.
Ok, finally got around to trying this… and it worked. thanks for the help! How do I know what drive the virtual machine is using for the partition?
