Latest Update cause 100% CPU consumption
ownCloud 5.3.1.14018 f15fd5
Libraries Qt 6.4.3, OpenSSL 3.1.2 1 Aug 2023
Using virtual files plugin: suffix
OS: macos-23.5.0
QPA: cocoa
The owncloud client should not consume 100% CPU performance.
Since the last update, owncloud consume >100% CPU performance on my MacBook Pro M1 Max with Sonoma 14.5. It’s quite difficult to work for the desktop client as the application reatcts very slowly.
  1. Update to version 5.3.1.14018 (f15fd5).
  2. Open owncloud client.
  3. owncloud client consume 100% CPU performance.
ownCloud version: 10.14.0.3 (stable)
Storage backend (external storage): NVMEs
Client version: ownCloud 5.3.1.14018 f15fd5
Operating system: macos-23.5.0 - MacOS Sonoma 14.5
OS language: German
Qt version used by client package (Linux only, see also Settings dialog): Qt 6.4.3
Client package (From ownCloud or distro) (Linux only): ownCloud
Installation path of client: /Programme/owncloud
Having that CPU fan whirring constantly is no fun. Hopefully someone familiar with the client-development side can chime in with a fix. In the meantime, maybe downgrading the client temporarily might be an option?
