Hi
I recently install OWNCLOUD with guidance of this page https://doc.owncloud.com/server/admin_manual/installation/quick_guides/ubuntu_18_04.html , now i want to install LDAP for authentication , i downloaded file from
https://marketplace.owncloud.com/apps/user_ldap that is compressed , after extracted it i didn’t khnow how to install LDAP and did not find any guide page the page is only for configuration
How do i install LDAP Package for owncloude?
Thank you
This is an app, and apps are to be installed directly via the market menu. But I strongly doubt that this alone is helpful for you.
nothing is in my app list about LDAP to enable or install !!! why it is like this ?
and would you tell what else do i need?
Thank you
I cannot. AFAIK you need an external user directory server. And this is not my area of interest.
I don’t get what you mean , i have Active Directory , i just want to know how to add LDAP to owncloud not creating directory server
Thanks for your attention
Then you could go ahead with the docs ?
docs just explained about configuration not installation .
As I said above, not my area of interest. Good luck for you!
You should have a “market” app already enabled. It should appear in the top left menu.
From the “market” app, you can download and install any of the apps showing there. The user_ldap app should be there too.
In Installing and Managing Apps :: ownCloud Documentation you have documentation about how ti manually install the apps, although using the market is recommended.
Thank you very much , i found it
system
Closed
September 5, 2021, 3:28am
#12
