LDAP sync gets lost. All employees get a message “all files from the sync folder got deleted. Do you want to keep or delete all files?” on the owncloud client.
All users get a new USER ID with a suffix (as seen in phpmyadmin) and therefore a new folder on the server.
This happened the SECOND time today since I’ve updated to 10.0.10
Operating system: Debian 3.16.39-1+deb8u2
Web server: Apache/2.4.10
Database: Ver 8.42 Distrib 5.5.54,
PHP version: PHP 5.6.38-0+deb8u1
"system": {
"instanceid": "51e4e89fdffd9",
"trusted_domains": [
"REMOVED SENSITIVE VALUE",
"192.168.0.31"
"datadirectory": "\/owncloud\/data",
"overwrite.cli.url": "hREMOVED SENSITIVE VALUE",
"dbtype": "mysql",
"version": "10.0.10.4",
"dbname": "owncloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"logtimezone": "UTC",
"installed": true,
"forcessl": true,
"theme": "",
"loglevel": 3,
"maintenance": false,
"trashbin_retention_obligation": "auto"
Enabled:
- activity: 2.3.8
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.4.0
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_pdfviewer: 0.9.0
- files_sharing: 0.11.0
- files_texteditor: 2.2.1
- files_videoplayer: 0.9.8
- market: 0.2.5
- notifications: 0.3.5
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.3.1
- updatenotification: 0.2.1
- user_ldap: 0.11.0
Disabled:
- encryption
- external
- files_trashbin
- files_versions
- firstrunwizard
- user_external
SELECT * FROM oc_appconfig WHERE appid = ‘user_ldap’;
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
#### Browser log
c) …
