LdapEnforceChannelBinding and owncloud
because of LdapEnforceChannelBinding our AD-Administrator configured a logfile to see, which servers will have problems after Microsoft enforces this option. And the owncloud is one of these servers.
I looked in the FAQ and the documentation, but I can’t find anything to reconfigure our owncloud for this.
  1. Check Logfile of Active Directory
Ubuntu 16.04.6 LTS
Server version: Apache/2.4.18 (Ubuntu)
mysql Ver 14.14 Distrib 5.7.28
PHP 7.0.33-0ubuntu0.16.04.7
10.3.2 (stable)
update from older Owncloud
APT
(Only the changed logos)
“system”: {
“updatechecker”: false,
“instanceid”: “ocduoax1kzk9”,
“trusted_domains”: [
“FQDN”,
“FQDN:443”
“datadirectory”: “/data”,
“overwrite.cli.url”: “owncloud-URL”,
“dbtype”: “mysql”,
“version”: “10.3.2.2”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“mysql.utf8mb4”: true,
“logtimezone”: “UTC”,
“installed”: true,
“memcache.distributed”: “\OC\Memcache\Redis”,
“memcache.locking”: “\OC\Memcache\Redis”,
“ldapIgnoreNamingRules”: false,
“integrity.check.disabled”: false,
“mail_smtpmode”: “smtp”,
“mail_smtpport”: “25”,
“loglevel”: 4,
“maintenance”: false,
“singleuser”: false,
“excluded_directories”: [
“.snapshot”,
“~snapshot”,
“@Recently-Snapshot”
“filesystem_check_changes”: 1,
“versions_retention_obligation”: “0, 0”
Enabled:
  • comments: 0.3.0
  • configreport: 0.2.0
  • dav: 0.5.0
  • federatedfilesharing: 0.5.0
  • federation: 0.1.0
  • files: 1.5.2
  • files_external: 0.7.1
  • files_mediaviewer: 1.0.1
  • files_sharing: 0.12.0
  • files_versions: 1.3.0
  • firstrunwizard: 1.2.0
  • market: 0.5.0
  • notifications: 0.5.0
  • provisioning_api: 0.5.0
  • systemtags: 0.3.0
  • updatenotification: 0.2.1
  • user_ldap: 0.14.0
    Disabled:
  • encryption
  • external
  • files_trashbin
  • user_external
yes: smb
no
Active Directory
LDAP configuration
What is that? What does it do?
You didn’t fill out the expected behaviour and what actually happens. So what is the problem, can you please explain?
Do you see any errors in the owncloud log? If not, can you set the following parameter in the config.php:
smb.logging.enable' => true,
Then it should definitely show an error message in the logs.
At the moment everything is working, but with Windows Update in March 2020 Microsoft enables a feature for Active Directory. With this feature only signed LDAP requests will work (to prevent mitm-attacks) and there will be no workaround. In the Eventlog of the AD server you can see requests, that will not work after installing this update in march and owncloud is one of these.
https://portal.msrc.microsoft.com/en-us/security-guidance/advisory/CVE-2017-8563
Information-summary (but only in german):
https://www.msxfaq.de/windows/sicherheit/ldapenforcechannelbinding.htm
I guess there is some development effort, so I would recommend to open a Github issue regarding this:
Thank you
If anyone finds this thread because of google, this is the issue on github:
Thank you @RodNoc I really appreciate it! We will take care :wink:
