How we can connect to windows AD LDAPS.
We have testet white the normal config LDAP this work corectly.
But how we must config to work withe LDAPS?
Use ldaps://<your-host>
as hostname in the user_ldap configuration. You might need to change the port (I think the default for ldaps is 636) and verify the certificates are in the default location (or disable certificate validation)
