kiko
January 21, 2020, 3:47pm
#1
i have an issue to get LDAPS working since we switched our infrastructure to ldaps
ldap_sasl_bind(SIMPLE): Can’t contact LDAP server (-1)
i forgot to tell you that my owncloud is in DMZ and the port 636 and 389 are open in the firewall
i didn’t find anything helpful in forums !!
please help !!
Thank you
Where are you getting this error message?
ownCloud 9.x is no longer supported, please upgrade.
kiko
January 22, 2020, 10:01am
#3
Thank you for your reply in fcat the version of my owncloud is 9.1.4 i thought that is support LDAPS i’am
how can i upgrade to the version 10 ?
Thank you
tom42
January 26, 2020, 1:57pm
#4
have you tried to have a look at the ownCloud documentation available at https://doc.owncloud.org ? I would expect that an answer how to upgrade should be available there.
