I am using Linux packages on a Centos 7 server for my owncloud deployment. I chose this option over the tarball in order to easily stay up to date with the latest bug fixes.
Anyway, I need to setup several completely separated owncloud deployments on one box for different projects. Now I wonder, if and how this is possible using Linux packages install. Yum directly installs all files into /var/www/html/owncloud and in there is the config.php file where you have to hard code the deployment details (DB, DB password, theme, etc.). So I see no option to have several deployments using the same install, right?
I would have to make copies of /var/www/html/owncloud and adjust the config.php file each time and keep the copies up to date manually. No way to symbolically link to /var/www/html/owncloud, right?
Best Regards,
Benedikt
