1.update and reboot client, clear cache
2.Click on icon and click on open open owncloud in browser
3.Wait for the browser window to open.
The connection to the server and login window should appear in a short period of time.
The credentials user-name and password input.
Connection to the host server made.
The icon shows a green check on one client (laptop) and goes grey.
The icon shows a green check on another client (desktop) and goes grey.
The client makes connection with the server and takes a long time to connect.
The client reads “Problem loading page, reloading in 5 seconds”.
The reload takes much longer than 5 seconds and fails.
The icon green check-mark goes on and off every few seconds.
Operating system: Linux Ubuntu 16.04
Web server: ?
Database: ?
PHP version: ?
ownCloud version (see ownCloud admin page):
Updated from an older ownCloud or fresh install: updated on 20 April 2017
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): none
ownCloud configuration
Go to the admin page, click on 'admin' -> 'Generate Config Report' -> 'Download ownCloud config report' or use the command line `sudo -u www-data php occ config:list system` (please sanitize sensitive data):
Integrity status for oC9+
[code]
paste the results here.
Exception: {“Message”:“HTTP/1.1 503 System in maintenance mode.”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 [internal function]: OCA\DAV\Connector\Sabre\MaintenancePlugin->checkMaintenanceMode(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#1 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#2 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(446): Sabre\Event\EventEmitter->emit(‘beforeMethod’, Array)\n#3 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#4 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(61): Sabre\DAV\Server->exec()\n#5 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#6 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/MaintenancePlugin.php”,“Line”:84,“User”:“my user name”}
