- Configure owncloud to use local cache reading the official documentation
- Try APCu (I installed php-apcu)
- Try Redis (I installed php-redis and redis-server)
Owncloud using apcu/redis as caching methode
Error message saying that the php module is missing or not enabled
apcu and redis php modules are enabled. Redis is configured as cache too with unix socket. both extentions config use the same name.so as official doc here. Redis is running and the sock is in place. Both version are superior as the version requested.
Operating system: Ubuntu 17.10 (I know you’re not compatible for it but I’ve the same error on 17.4 just before dist-upgrade)
Web server: Apache/2.4.27
Database: mysql Ver 14.14 Distrib 5.7.21
PHP version: PHP 7.1.11
ownCloud version: 10.0.5.4
Updated from an older ownCloud or fresh install: Updated from 9.something (don’t remimber which version)
Where did you install ownCloud from: Official repo for Ubuntu from owncloud docs
Signing status (ownCloud 9.0 and above): Memcache \OC\Memcache\Redis not available for local cache Is the matching PHP module installed and enabled?
"system": {
"trusted_domains": [
"forcessl": true,
"instanceid": "oc7bd28573e8",
"overwrite.cli.url": "***REMOVED SENSITIVE VALUE***",
"dbtype": "mysql",
"version": "10.0.5.4",
"dbname": "owncloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"installed": true,
"mail_smtpmode": "php",
"maintenance": false,
"loglevel": "2",
"memcache.local": "\\OC\\Memcache\\Redis",
"redis": {
"host": "/var/run/redis/redis.sock",
"port": 0
"enable_previews": true,
"updatechecker": false,
"theme": ""
Enabled:
- activity: 2.3.6
- announcementcenter: 1.2.0
- audioplayer: 2.2.4
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.3.2
- encryption: 1.3.1
- federatedfilesharing: 0.3.1
- files: 1.5.1
- files_external: 0.7.1
- files_pdfviewer: 0.8.2
- files_sharing: 0.10.1
- files_texteditor: 2.2.1
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- gallery: 16.0.2
- market: 0.2.3
- notifications: 0.3.2
- polls: 0.8.0
- provisioning_api: 0.5.0
- security: 0.0.2
- systemtags: 0.3.0
- templateeditor: 0.2
- updatenotification: 0.2.1
Disabled:
- external
- federation
- theme-example
- user_external
Are you using external storage, if yes which one: NO
Are you using encryption: yes
Are you using an external user-backend, if yes which one: Not as I know
Browser: Chrome Version 63.0.3239.108
Operating system: Fedora 27
NO - ERROR
{"reqId":"QVq2hXXiqBNv2k3jVxat","level":3,"time":"2018-01-25T12:50:53+00:00","remoteAddr":"127.0.0.1","user":"--","app":"core","method":"GET","url":"\/owncloud\/index.php\/settings\/integrity\/failed","message":"Memcache \\OC\\Memcache\\Redis not available for local cache Is the matching PHP module installed and enabled?"}
{"reqId":"QVq2hXXiqBNv2k3jVxat","level":3,"time":"2018-01-25T12:50:53+00:00","remoteAddr":"127.0.0.1","user":"--","app":"core","method":"GET","url":"\/owncloud\/index.php\/settings\/integrity\/failed","message":"Exception: {\"Exception\":\"OC\\\\HintException\",\"Message\":\"Memcache \\\\OC\\\\Memcache\\\\Redis not available for local cache\",\"Code\":0,\"Trace\":\"#0 \\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/Server.php(410): OC\\\\Memcache\\\\Factory->__construct('0376c8c707dea67...', Object(OC\\\\Log), '\\\\\\\\OC\\\\\\\\Memcache\\\\\\\\Re...', '\\\\\\\\OC\\\\\\\\Memcache\\\\\\\\Re...', '\\\\\\\\OC\\\\\\\\Memcache\\\\\\\\Re...')\\n#1 \\\/home\\\/www\\\/owncloud\\\/lib\\\/composer\\\/pimple\\\/pimple\\\/src\\\/Pimple\\\/Container.php(113): OC\\\\Server->OC\\\\{closure}(Object(OC\\\\Server))\\n#2 \\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Utility\\\/SimpleContainer.php(111): Pimple\\\\Container->offsetGet('MemCacheFactory')\\n#3 \\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/ServerContainer.php(87): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->query('MemCacheFactory')\\n#4 \\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/Server.php(1141): OC\\\\ServerContainer->query('MemCacheFactory')\\n#5 \\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/Server.php(557): OC\\\\Server->getMemCacheFactory()\\n#6 \\\/home\\\/www\\\/owncloud\\\/lib\\\/composer\\\/pimple\\\/pimple\\\/src\\\/Pimple\\\/Container.php(113): OC\\\\Server->OC\\\\{closure}(Object(OC\\\\Server))\\n#7 \\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Utility\\\/SimpleContainer.php(111): Pimple\\\\Container->offsetGet('AppManager')\\n#8 \\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/ServerContainer.php(87): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->query('AppManager')\\n#9 \\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/Server.php(1359): OC\\\\ServerContainer->query('AppManager')\\n#10 \\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/legacy\\\/app.php(566): OC\\\\Server->getAppManager()\\n#11 \\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/L10N\\\/Factory.php(313): OC_App::getAppPath('search')\\n#12 \\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/L10N\\\/Factory.php(191): OC\\\\L10N\\\\Factory->findL10nDir('search')\\n#13 \\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/L10N\\\/Factory.php(227): OC\\\\L10N\\\\Factory->findAvailableLanguages('search')\\n#14 \\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/L10N\\\/Factory.php(165): OC\\\\L10N\\\\Factory->setLanguageFromRequest('search')\\n#15 \\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/legacy\\\/util.php(581): OC\\\\L10N\\\\Factory->findLanguage('search')\\n#16 \\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/legacy\\\/util.php(554): OC_Util::addTranslations('search')\\n#17 \\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/legacy\\\/template.php(139): OC_Util::addScript('search', 'search', true)\\n#18 \\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/legacy\\\/template.php(81): OC_Template::initTemplateEngine('error')\\n#19 \\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/legacy\\\/template.php(332): OC_Template->__construct('', 'error', 'error', false)\\n#20 \\\/home\\\/www\\\/owncloud\\\/index.php(65): OC_Template::printErrorPage('Memcache \\\\\\\\OC\\\\\\\\Me...', 'Is the matching...')\\n#21 {main}\",\"File\":\"\\\/home\\\/www\\\/owncloud\\\/lib\\\/private\\\/Memcache\\\/Factory.php\",\"Line\":95}"}
Request URL:https://**********************/owncloud/index.php/settings/integrity/failed
Request Method:GET
Status Code:500 Internal Server Error
Remote Address:**********************:443
Referrer Policy:no-referrer-when-downgrade
