- Add this in config file (‘files_external_allow_create_new_local’ => true,)
2.configure the external storage settings
I should be able to see the files on my mounted and configured drive
I get rediercted to home page
Zorin 15.3 (based of ubuntu 18.04)
apache2
MariaDB
10.1.1
Older
Official site steps
I dont know what it is
https://pastebin.com/p0Uj8uW9
“config”: {
“instanceid”: “oc4mae2k9g5r”,
“trusted_domains”: [
“49.205.105.88”,
“192.168.0.106”
“datadirectory”: “/var/www/html/owncloud/data”,
“overwrite.cli.url”: “http://49.205.105.88/owncloud”,
“dbtype”: “mysql”,
“version”: “10.1.1.1”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“logtimezone”: “UTC”,
“installed”: true,
“updater.secret”: “REMOVED SENSITIVE VALUE”,
“loglevel”: 2,
“maintenance”: false,
“theme”: “”,
“files_external_allow_create_new_local”: true
Nothing extra. Only the ones that came with the install
Local (/media/username/device_name)
NO
Problem with all tested browser
windows 10 pro
