Localhost/owncloud giving 404
  1. after a fresh install I cannot access the login/setup page through localhost/owncloud
owncloud sign in page should display
the page goes directly to 404
Operating system: ubuntu 16.04
Web server: apache2
Database: sql
PHP version: 7.0
ownCloud version: 10.0.7-1.1
Where did you install ownCloud from: owncloud linux package
List of activated apps: not there yet
Are you using encryption: no
Browser: firefox
I am still a newbie with linux in general, so when I screw something up I just reinstall Ubuntu and then OC. My setup has been doing great but I saw there was an upgrade to OC 10 and I wanted to install it. I did a clean wipe of Ubuntu like I have done many times and installed OC 10. I install the LAMP stack and then the php 7.0 intl, curl and php 7 zip. The 3 php installation files are new to me because OC worked fine for me with the LAMP stack before and this may be what changes things but I’m not sure. When I try to access the OC setup and login page it comes back as a 404. I have never had this happen before. Now, if I move the OC installation to the HTML folder it will work. When I did this I could not get marketplace apps because it said the apps folder is writable. So I figured this had something to do with moving the folder but I’m not sure. If I remember correctly, when you install OC the folder the path was /var/www/owncloud. Did something change with OC? I read somewhere that people are using symbolic links. I have never done one. Any help would be appreciated.
for new people there is the ownCloud doc with useful info:
https://doc.owncloud.com/server/10.0/admin_manual/
I have looked there but I didn’t see anything related to it. Thank you for the response.
Maybe the Apache configuration is missing?
That makes sense but where does the newly created file go? Normally OC worked right after you installed it. I just don’t want to mess it up, lol. Thank you.
You mean this one?
/etc/apache2/sites-available/owncloud.conf
So do I create my conf file exactly like this? ownCloud Documentation Overview
Where do I put the file once I create it? The default OC installation is /var/www/owncloud. I know this is simple for a lot of you but I’m not very good with this stuff and I get confused easily. Any and all help is appreciated.
Do I do this conf file too?
No Problem.
you just open a editor. “nano” or “vi” or “vim”.
For example with nano it would be like:
nano /etc/apache2/sites-available/owncloud.conf
then you copy the content from the doc:
Alias /owncloud "/var/www/owncloud/"
<Directory /var/www/owncloud/>
  Options +FollowSymlinks
  AllowOverride All
 <IfModule mod_dav.c>
  Dav off
 </IfModule>
 SetEnv HOME /var/www/owncloud
 SetEnv HTTP_HOME /var/www/owncloud
</Directory>
paste it in your terminal window where you have the editor opened.
save it, by pressing str+o, enter
now you just have to create a symlink by executing this command:
ln -s /etc/apache2/sites-available/owncloud.conf /etc/apache2/sites-enabled/owncloud.conf
The location of this file is in /etc then apache2 and there is a folder “sites-available” there should be the file that we just created.
If you have further questions, don’t hesitate to ask, we were all beginners at some point :slight_smile:
Sorry I’m late getting back to you. Thank you dmitry! I will try it this morning. I wonder why they changed this from how it used to be.
I guess I did something wrong because it didn’t work. I will walk back through it again and see what happened. I followed it and did what it says but maybe i had a typo or something.
LOL, now it says I can’t write when I try to run OC. I used to do the LAMP installer and then make a few tweaks. I saw that OC has package installers with the php stuff. Do I still do the LAMP install and then do the package or just run the package only? I had OC setup before with a separate mount for the file storage. I have used a text file that I just copy and paste each command to get the LAMP and OC setup and it worked fine. I don’t really know what I need to use and not use for OC10. I have read the admin manual but stuff skips all over the place and I don’t know what I have to do and when to do it. I know I may not being using the right terms and I’m sorry for that. Any help would be appreciated.
