What is lock file status in owncloud and how to prevent it for happening?
I tried to remove lock file message by putting Maintainence Mode = True , and then deleting key =1 from oc_files_locked , still i am receiving message in my owncloud desktop client about file locks though I think some of the files has gone.
I recently did an upgrade and found that my cron script was not running (after a user reported a file was locked). This is from version 10.0.2 to 10.0.3. You can manually run the cron.php if you have CLI access. Try:
and see if that will clear the locking issue for you. You can also check the status of your cron jobs and how they are configured in the administration console > General and scroll to the bottom.
How can we sure that the cron job is running on a shared host?
Hosting: infomaniak.com
I dont know if there is a solution to have CLI access to oc command.
Thank you.
Igor
