Hi and thank you for reading this, i have some problems with my owncloud installation as you can see below, fact is i tried to set up a logrotate to take the log and archive it to not have a huge log to read through and find errors faster.
I’m medium experienced with serverside debian stuff and try to do it on my own, set up all the stuff and this is my first post here, sorry if it’s a bit scrambled.
Thanks a lot.
Owncloud logging in /etc/www/owncloud/data/owncloud.log
Owncloud log missing, not being written or something like that
Debian 9
Apache 2
mySQL
10.1.0.4
fresh
i think it was git clone?
i don’t know what this means.
<?php $CONFIG = array ( 'updatechecker' => false, 'instanceid' => 'ocvtuiuxcmos', 'passwordsalt' => 'REDACTED', 'secret' => 'REDACTED', 'trusted_domains' => array ( 0 => '192.168.1.236', 1 => 'REDACTED', 2 => 'REDACTED', 3 => 'REDACTED', ), 'datadirectory' => '/var/www/owncloud/data', 'overwrite.cli.url' => 'http://192.168.1.236', 'dbtype' => 'mysql', 'version' => '10.1.0.4', 'dbname' => 'owncloud', 'dbhost' => 'localhost', 'dbtableprefix' => 'oc_', 'dbuser' => 'REDACTED', 'dbpassword' => 'REDACTED', 'logtimezone' => 'UTC', 'installed' => true, 'mail_domain' => 'REDACTED', 'mail_from_address' => 'ownCloud', 'mail_smtpmode' => 'smtp', 'mail_smtpauthtype' => 'LOGIN', 'mail_smtpauth' => 1, 'mail_smtphost' => 'REDACTEDt', 'mail_smtpport' => '25', 'mail_smtpname' => 'REDACTEDt', 'mail_smtppassword' => 'REDACTED', 'memcache.local' => '\\OC\\Memcache\\Redis', 'filelocking.enabled' => 'true', 'memcache.distributed' => '\\OC\\Memcache\\Redis', 'memcache.locking' => '\\OC\\Memcache\\Redis', 'redis' => array ( 'host' => 'localhost', 'port' => 6379, 'timeout' => 0, 'dbindex' => 0, ), ); ``` Log in to the web-UI with an administrator account and click on 'admin' -> 'Generate Config Report' -> 'Download ownCloud config report' This report includes the config.php settings, the list of activated apps and other details in a well sanitized form. or If you have access to your command line run e.g.: sudo -u www-data php occ config:list system from within your ownCloud installation folder *ATTENTION:* Do not post your config.php file in public as is. Please use one of the above methods whenever possible. Both, the generated reports from the web-ui and from occ config:list consistently remove sensitive data. You still may want to review the report before sending. If done manually then it is critical for your own privacy to dilligently remove *all* host names, passwords, usernames, salts and other credentials before posting. You should assume that attackers find such information and will use them against your systems. ``` **List of activated apps:** Enabled: - activity: 2.4.2 - brute_force_protection: 1.0.1 - camerarawpreviews: 0.6.4 - comments: 0.3.0 - configreport: 0.1.2 - dav: 0.4.0 - federatedfilesharing: 0.3.1 - federation: 0.1.0 - files: 1.5.2 - files_external: 0.7.1 - files_external_dropbox: 1.1.0 - files_external_ftp: 0.2.1 - files_sharing: 0.11.0 - files_trashbin: 0.9.1 - files_versions: 1.3.0 - files_videoplayer: 0.9.9 - firstrunwizard: 1.1.1 - gallery: 16.1.1 - market: 0.4.0 - notifications: 0.4.1 - ownbackup: 19.1.0 - password_policy: 2.0.2 - provisioning_api: 0.5.0 - systemtags: 0.3.0 - updatenotification: 0.2.1 - wallpaper: 0.1 Disabled: - encryption - external - user_external ``` If you have access to your command line run e.g.: sudo -u www-data php occ app:list from within your ownCloud installation folder. ``` **Are you using external storage, if yes which one:** local/smb/sftp/... smb **Are you using encryption:** yes/no no **Are you using an external user-backend, if yes which one:** LDAP/ActiveDirectory/Webdav/... no ### Client configuration **Browser:** Firefox **Operating system:** Win7 ### Logs #### Web server error log ``` Insert your webserver log here ``` #### ownCloud log (data/owncloud.log) ``` Insert your ownCloud log here ``` #### Browser log ``` Insert your browser log here, this could for example include: a) The javascript console log b) The network log c) ... ```
