I recently updated OC to v10, at which point I noticed the log was almost 400 MB…
[root@cyndane logrotate.d]# ls -lh /home/owncloud/data/owncloud.log
-rw-r-----. 1 apache apache 368M Jun 9 09:15 /home/owncloud/data/owncloud.log
Searching the web and testing the log_rotate_size in config.php didn’t do it for my install. I kept getting CSRF-errors which were only resolved by temporarily disabling the files_sharing module from the CLI.
So I turned to the built-in logrotate daemon, and this is how I did it. Hopefully it may be of help to others.
Assuming root access is available.
This is on CentOS 6.9 x64.
Owncloud data-folder is located in /home/owncloud, ie /home/owncloud/data/owncloud.log
- Create a file called owncloud in /etc/logrotate.d.
- Enter the below.
monthly
rotate 3
compress
missingok
notifempty
create 644 apache apache
postrotate
/usr/bin/killall -HUP rsyslogd
endscript
- Save and close the file.
- Test the logrotation manually.
logrotate -f /etc/logrotate.d/owncloud
-rw-r–r-- 1 apache apache 0 Jun 9 09:23 /home/owncloud/data/owncloud.log
That’s it.
@adrianvg thanks for this info… I am on a shared hosted web server and I do have access to the folders you refer to and I can create the file where you state but after that I’m not really sure what to do… I am sure my log file is just way to big its now almost 600M and I really want to either delete or archive it or something
EDIT: I did delete the file and let it create a new one until I can figure this out
Sorry for the incredibly late reply, but for some reason I don’t get any alerts to my posts.
After having created the file /etc/logrotate.d/owncloud, that should be it.
The log will be rotated automagically in the background.
Just in case, check that /etc/logrotate.d/owncloud has permissions set to 644.
See the docs ownCloud Documentation Overview
There is log_rotate_size which will rotate the log based on it’s size
Yeah, that didn’t work for me for some reason. I just got loads of CSRF-errors.
I see - good to know … we will test this … THX
I’ve tried logrotation with 10.0.2 , 10.0.3beta and the current git version and cannot reproduce that issue
So here is how I’ve tested:
- in the
config.php set
'log_rotate_size' => 10485760,
'loglevel' => 0,
- copied 10480760 bytes of random data into the log file
- run UI tests to simulate all kind of user activity
After a while the log gets rotated and I have messages like this in the logfile:
{"reqId":"fE3gDwW0lmgi22cuVF1H","level":0,"time":"2017-08-21T11:50:25+00:00","remoteAddr":"::1","user":"--","app":"cron","method":"GET","url":"\/owncloud-core\/cron.php","message":"Finished background job, the job took : 0 seconds, this job is an instance of class : OC\\Log\\Rotate with arguments : \/home\/artur\/www\/owncloud-core\/data\/owncloud.log"}
would you mind tell me the exact version you are using or even fill the github issue template: Sign in to GitHub · GitHub
Individual-it,
Was yours a fresh OC install?
I’m thinking my non-fresh installs (ie updates over previous installs) and certificate tinkering to harden stuff, may have done something.
My current version:
System Status
installed true
maintenance false
needsDbUpgrade false
version 10.0.2.1
versionstring 10.0.2
edition Community
productname ownCloud
Could you also please post the content of config/config.php
Real url replaced with “fqdn.com”.
[root@cyndane owncloud]# sudo -u apache php occ config:list system
“system”: {
“instanceid”: “ocfdfc96a2a2”,
“trusted_domains”: [
“fqdn.com”,
“www.fqdn.com”,
“192.168.0.9”
“datadirectory”: “/home/owncloud/data”,
“dbtype”: “mysql”,
“version”: “10.0.2.1”,
“installed”: true,
“maxZipInputSize”: 5261334937.6,
“allowZipDownload”: true,
“forcessl”: false,
“theme”: “”,
“maintenance”: false,
“mail_smtpmode”: “php”,
“loglevel”: 1,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“mail_from_address”: “webmaster”,
“mail_domain”: “fqdn.com”,
“has_internet_connection”: true,
“memcache.local”: “\OC\Memcache\APCu”,
“memcache.locking”: “\OC\Memcache\Redis”,
“redis”: {
“host”: “localhost”,
“port”: 6379
“trashbin_retention_obligation”: “15, auto”,
“updatechecker”: true,
“updater.server.url”: “https://updates.owncloud.com/server/”,
“preview_libreoffice_path”: “/usr/bin/libreoffice”,
“enable_previews”: true,
“overwrite.cli.url”: “http://www.fqdn.com/owncloud”
But that is not the config that gives you trouble because it does not have any log_rotate_size set. Or do I misunderstand something?
Probably a misunderstanding
In my first post I wrote that the log_rotate thing in the config-file didn’t work for me.
Or maybe I misunderstood you?
The script works for me now. The log_rotate command did not. I’m satisfied that it works now. I don’t neccesarily need the setting in the config-file.
I would like to find out why the internal log rotate does not work for you and possible fix it.
Because I could not reproduce the log_rotate problem you described in the beginning I would appreciate your help to find out how to reproduce that issue
I’ll try it again this weekend.
I’ll be back!
